Author Topic: mala jukebox  (Read 3981 times)
glyndawn
  • Last login:January 05, 2009, 03:37:09 am
mala jukebox
« on: October 30, 2008, 04:31:50 am »
hi folks
im goin to use mala built in juke box ive clicked the box use jukebox named it and pointed it to my mp3s
come out of options menu now where is it how do i start it
loadman
    • MaLa
Re: mala jukebox
« Reply #1 on: October 30, 2008, 06:37:39 pm »
hi folks
Just to start, the Jukebox has a few bugs (fixed in the next version)  ;)
To switch to jukebox you can either.
1) right click on screen - swlect emulator- Juke box should be in the list. If it isn't you need to check the checkbox in options - sound and music - jukebox
2) Use the allocated keys you have set in controllers to move between next and previous emulator.
glyndawn
Re: mala jukebox
« Reply #2 on: November 01, 2008, 12:44:01 pm »
its still not working all it says in the jukebox screen is add files ?
austin_21b
  • Last login:April 22, 2009, 09:59:29 pm
Re: mala jukebox
« Reply #3 on: November 01, 2008, 02:30:47 pm »
I have a suggestion for the Mala jukebox. You  could use windows media player to power it. There is a separate app that does this. Its called Jukebox Arcade. One of the things I like is that after a period of time, it switches to your media player visualization. The only problem is that its not very easy to navigate with just a keyboard.
loadman
    • MaLa
Re: mala jukebox
« Reply #4 on: November 01, 2008, 06:03:01 pm »
You are just adding MP3's right?  As opposed to wma or others
« Last Edit: November 01, 2008, 09:29:44 pm by loadman »
NebulaSleuth
  • Last login:July 11, 2012, 10:27:33 am
Re: mala jukebox
« Reply #5 on: November 17, 2008, 04:05:11 am »
As the author of Jukebox Arcade, I'd love to know what you think would make navigation with keyboard easier.
