Author Topic: Diagnosis...  (Read 901 times)
venkman
  • Last login:January 28, 2013, 02:44:28 am
Diagnosis...
« on: October 29, 2008, 05:34:14 am »
nothing to do with dick van dyke, but some troubleshooting help would be great!
a new machine arrived yesterday and it doesn't work.   :cry:
here are the things i know:
  • it's a jamma machine
  • has an adaptor so it powers 2 games and can (apparently) switch between them.
  • all connections seem to be in ok.
  • when i plug in the machine and turn it on the monitor comes on - it lights up and displays a kind of light grey screen with nothing on it.
  • the power supply's red light doesn't come on.
does this mean that it's most probably the power supply and i should firstly try replacing the power supply? anything else i can check?
.. how come the monitor works if the power supply isn't working - does it take power direct from the mains you think?
SirPeale
  • Green Mountain Man
Re: Diagnosis...
« Reply #1 on: October 29, 2008, 05:38:21 am »
Use your multimeter and start checking voltages and fuses.
venkman
Re: Diagnosis...
« Reply #2 on: October 29, 2008, 05:47:41 am »
thanks, ok i'll check the voltage coming out of the power supply first off. i don't know where else i could check. the other end of the wires maybe..
SirPeale
Re: Diagnosis...
« Reply #3 on: October 29, 2008, 06:50:15 am »
Fuses, if there are any.  And check the AC going in to the power supply.
venkman
Re: Diagnosis...
« Reply #4 on: October 29, 2008, 07:56:41 am »
just to make sure the power from the wall is working at 240. ok..
i have a spare power supply in the other non-working cab i have. i'll test that one too.
if the power going in to the power supply that doesn't seem to be working (the led is off) is ok, but no power is coming out - the PSU will most likely be the culprit?
so.. the multi meter is really just helping me be more definite.
i'm not sure if the cab has any fuses i can test.
if the voltages going in and coming out on the one i have at home are ok then i can swap it in.  this one has a working red led on it but the rest of the machine is broken.
.. such a mess of wires in there!
