Author Topic: Flyback & Yoke Test??  (Read 2107 times)
jconstanza
  • Last login:April 23, 2009, 02:28:02 pm
« on: October 27, 2008, 12:36:52 pm »
How to you test these parts? Can I use a regular multimeter or do I need other type of equipment? What type of good/bad readings should I be getting? Are different models different in the way of testing and/or do I get different readings.
grantspain
Re: Flyback & Yoke Test??
« Reply #1 on: October 27, 2008, 01:25:36 pm »
you can check the yoke with a multimeter set on ohms,there are two pairs of wires(normally red ,blue pair and green,yellow pair)
a standard cga reading would around 1.6 ohms horizontal and anything from 5 to 14 ohms vertical
i knew a few years back a fella tested flybacks by metering the ground pin to another,can't remember and i bet its different for every flyback
Ken Layton
  • Guru
  • Technician
« Reply #2 on: October 27, 2008, 02:38:08 pm »
Flybacks can be tested (out of circuit) with a special meter called a flyback tester.
dewmanSNK
  • Newbie
  • Last login:October 27, 2008, 03:48:47 pm
« Reply #3 on: October 27, 2008, 03:48:47 pm »
So there is no way to say 100% for sure that a flyback is good or bad when it is installed in the chassis?
jconstanza
« Reply #4 on: October 27, 2008, 03:56:33 pm »
Is it worth getting something like this?
http://www.mcmelectronics.com/product/78-220
grantspain
« Reply #5 on: October 27, 2008, 04:07:34 pm »
you could buy 8 brand new monitors for that :P
