Author Topic: TECH: Waves on WG 19K4615 FIXED  (Read 2072 times)
Tenn_pin
  • Last login:January 01, 2014, 06:57:02 pm
« on: October 26, 2008, 08:57:51 am »
This monitor has what looks to be interference waves that will "move in" and then " move out," if that makes any sense.  The screen is bright and colors look great, only these waves, that act like an ocean tide, keep comming and then going?  Any suggestions?
R
« Last Edit: November 08, 2008, 11:33:46 pm by Tenn_pin »
Ken Layton
  • Guru
  • Technician
Re: TECH: Waves on WG 19K4615
« Reply #1 on: October 26, 2008, 01:39:12 pm »
Temporarily unplug the degausser coil that runs around the outer perimeter of the picture tube. Usually the coil is wrapped with black electrical tape.
Tenn_pin
« Reply #2 on: October 26, 2008, 03:27:37 pm »
When do I do that?  After unit is off or during operation?
R
Ken Layton
  • Guru
  • Technician
« Reply #3 on: October 26, 2008, 03:36:05 pm »
Unplug it when the power is off (for your safety).
Tenn_pin
« Reply #4 on: October 27, 2008, 08:46:39 pm »
I have unplugged the degasser, but there are still waves.  I did a lot of adjusting and the waves disappeared, but the picture was very dark.  I turned up the screen, then the lines came back and I cannot get them to go again.  Is there a recommended adjustment for this monitor.  It is in a Pitfighter Vid.
R
sephirothq
  • Newbie
  • Last login:November 01, 2008, 11:55:51 pm
« Reply #5 on: November 01, 2008, 12:01:28 am »
I am having a similiar problem with a WG4600 in a pacman machine.  When the brightness is turned down it is dark but ok.  When i increase the brightness it have vertical spring like lines running across the monitor.  Any ideas on where i should start to look for problems.
Tenn_pin
« Reply #6 on: November 01, 2008, 07:27:20 pm »
I will just try to adjust tomorrow.  I will post any results tomorrow.
R
Tenn_pin
« Reply #7 on: November 08, 2008, 11:33:04 pm »
Turns out there was not a groung to the outside of the JAMMA board.  I ran a wire from the moniton chassie to the board (mounted to a screw hole in the corner), and then to the power supply. Each wire I added removed a level of waves.
R
