Author Topic: How do i wire in my coindoor?  (Read 1537 times)
notroubleclubber
  • Last login:October 07, 2023, 04:26:25 pm
« on: October 25, 2008, 09:28:20 am »
Ive done a mame conversion on my neo geo mv4 cab. Basically chopped the wires at the jamma connection end and wired them into the ipac.
Ive wired a seperate button to the ipac for coins (prog it for 5) but would like to start using the coin door again. It worked --BINGO! Either that, or I was attempting to say "before" but it was too many letters to type-- converting so how do i wire it up? I will put a keyswitch on the seperate button i got so i can turn off the credit button when i want to.
I wanted to start using my cab as money box hence why i want the coin door working.
FrizzleFried
    • Idaho Garagecade
Re: How do i wire in my coindoor?
« Reply #1 on: October 25, 2008, 10:47:44 am »
Unfortunately,  this is one of those topics that can't  be discussed in these forums.  See,  MAMEDev,  for legal purposes,  frowns on coin door usage and being that this is a MAME friendly site,  I am guessing this post will be shot to POST HELL in no time flat.
Now that said,  keep in mind that a coin door simply has a microswitch in the path of the coin that gets hit causing a credit to be added.  With that in mind,  take a look at your coin door and work your way back from the switch.
