Author Topic: How to get the best finish using spray paint on MDF?  (Read 11070 times)
massive88
« on: October 23, 2008, 10:30:27 am »
So far I have followed Timoe's advice here - http://forum.arcadecontrols.com/index.php?topic=66008.msg875767#msg875767
And have put on my second coat of oil based primer.  I will be painting the MDF black tonight or tomorrow.
Does anyone have any experience making those super glossy piano-type finishes and has insight they want to share?  Should I polish the Black Coats using any sort of rubbing compound?  What about the Clear coat?  Has anyone used High Gloss Wipe on Polycrylic instead of spray for this?
I used the wipe on for my wooden box, and was happy with the results, should I use what I am comfortable with or will the spray paint can version give me a better finish?
Really Im just looking for any tips or tricks as I head into the final painting stages.  I really want to nail this the first time and get it as good as it can be, Im on a sort of deadline with this project and will not have time to redo it if I fubar it.
  • Last login:March 05, 2026, 12:10:15 pm
Re: How to get the best finish using spray paint on MDF?
« Reply #1 on: October 23, 2008, 11:08:59 am »
You can read how I did it at www.bellasarcade.blogspot.com
I put a pink piano finish on the sides and back of my cab and it came out great.  Check the posts around the middle of 2007 (starting in April, I think).  This shot gives you an idea of the results (check out the reflection):
« Last Edit: October 23, 2008, 11:18:38 am by javeryh »
« Reply #2 on: October 24, 2008, 01:06:49 pm »
Wow.  I need to learn how to do that.
« Reply #3 on: October 26, 2008, 08:36:55 am »
It was the first - and likely last - time I try something like that.  What a pain!!   ;D
« Reply #4 on: October 27, 2008, 10:38:40 am »
How durable does it seem like it's going to be?  I wouldn't mind all the sanding passes but it would tick me off badly if I did all that and then you could nick the paint with a tennis ball.
« Reply #5 on: October 27, 2008, 11:16:59 am »
It seems to be holding up quite well but it has only been a year.  There are no scratches or nicks in the surface.  The clear coat dries pretty hard.  I'm very happy with it but the process was very long and took a lot of patience.
