Author Topic: Atari Power supply rebuilding...  (Read 18921 times)
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« on: October 21, 2008, 11:47:50 pm »
In the past, I've replaced Big Blue in a couple Atari power supplies, and if warranted, some fuse holders. Now, I see Bob sells a kit that also replaces the bridge rectifier. How reliable are bridge rectifiers? I'm just wondering if it's at all necessary to replace a perfectly good original for reliability? (Caps tend to age; so what about diodes?)
NO MORE!!
sarge
  • Last login:April 27, 2015, 01:42:54 pm
Re: Atari Power supply rebuilding...
« Reply #1 on: October 21, 2008, 11:54:59 pm »
Diodes have no tendency to break down with age.  Usually the only thing that will kill a diode is exceeding its current rating.  Electrolytic capacitors only die with age because the electrolyte dries up in them with heat and time.
Level42
« Reply #2 on: October 22, 2008, 11:13:52 am »
I agree. Not needed. Think about how long LED's live......those are diodes too !
« Reply #3 on: October 22, 2008, 11:18:02 am »
I don't entirely agree.  I have seen an awful lot of hard to diagnose issues in pinball machines go away by replacing the BRs.  I suspect a lot of failures would be prevented if we got to the bridge before it failed on us.
Level42
« Reply #4 on: October 22, 2008, 11:24:05 am »
I that your own experiences or from reading pinball threads ?
« Reply #5 on: October 22, 2008, 11:28:37 am »
Some of both.  Threads have been mostly consistent with what I've seen myself.  It's cheap to do, right?  Your power supply is the most important part of the game in terms of reliability.
Ken Layton
  • Guru
  • Technician
« Reply #6 on: October 22, 2008, 01:18:33 pm »
In the Atari power brick, the bridge rectifier is really heat-sinked pretty well and dissipates the heat well. I've seen far fewer bridge rectifier failures in Atari power bricks than in a pinball machine.
In pinball machines (Williams in particular) the bridge rectifiers are NOT heat-sinked well at all. Seems like they get too hot and fail from heat. I've lost count of how many bridge rectifiers I've replaced in Williams/Data East/Sega pinballs over the years, but it's over the 100 mark for sure.
You know how many bridge rectifiers I've replaced in Atari power bricks over the past 25 years? Only SIX!
Neverending Project
    • Arcade Fixer
« Reply #7 on: October 22, 2008, 03:35:59 pm »
What's impressive is that you remember the exact number... did you name them?  ;)
Level42
« Reply #8 on: October 22, 2008, 06:21:15 pm »
Thanks Ken, as always the best info around !
So, the conclusion is that diode's (BR's) don't go unless you torture them :) I guess the BR's also have a much higher load on pinballs than on videogames.
Ken, did those 6 have any "follow-up" damage from the BR going bad ? I guess the fuses will go very quickly when one of the diode's in a BR goes bad ?
« Last Edit: October 22, 2008, 06:23:13 pm by Level42 »
Ken Layton
  • Guru
  • Technician
« Reply #9 on: October 22, 2008, 07:51:19 pm »
Burnt quick connect terminals on the bridge rectifier when the rectifier went bad.
mwade109
  • Last login:May 16, 2021, 10:13:30 am
  • With enough $$$ anything can be fixed.
    • My youtube channel
« Reply #10 on: March 31, 2021, 03:40:20 pm »
Hey, I am about to rebuild two Atari Brick power supplies to sell (need to clear out some of the bulky stuff) and came across something perplexing. I believe they both came out of original Centipede machines but one of the power supplies has the bridge rectifier as usual and the other has no marking of it ever being there, there is usually a square mark or something on the chassis or discolored and no unhooked wires.  Have you ever seen this? Was this one maybe NOT from a Centipede?
-mike
« Last Edit: March 31, 2021, 04:11:53 pm by mwade109 »
Ken Layton
  • Guru
  • Technician
« Reply #11 on: March 31, 2021, 09:25:40 pm »
You have seperate diodes on a little circuit board attached to "Big Blue". So I would say that brick is likely out of some other game than a Centipede.
jennifer
« Reply #12 on: April 01, 2021, 06:05:57 am »
« Last Edit: April 14, 2021, 11:21:48 pm by jennifer »
« Reply #13 on: April 18, 2021, 02:37:13 pm »
Since I see this thread is revived, I have to ask a question at the risk of sounding ignorant...Is an Atari power supply even required to run an Atari cab? I mean, I know it is designed to do everything, iso transformer, and supply power at a unique set of voltages to the boards, but I have seen a a number of Atari cabs with separately isolated monitors swapped in already. At that point, wouldn't it be easier to get a couple switching power supplies and possibly a buck converter and tune the voltage pot to what is needed by the main and sound board? Aside from matching molex connectors and simply trying to be authentic, I am wondering if there really is a need to drop money into replacing an atari power supply.  :dunno
nitrogen_widget
« Reply #14 on: August 30, 2021, 09:23:58 pm »
I have a centipede pcb coming that will probably need repair.
not sure, it's missing some chips that I also have coming.
I want to know the answer to this question also.
i probably should of researched more before i bought it because these things cost more than the PCB on ebay.
Ken Layton
  • Guru
  • Technician
« Reply #15 on: August 30, 2021, 11:54:50 pm »
Some Atari game boards require oddball voltages and therefore must use the power brick and power supply board.
nitrogen_widget
« Reply #16 on: August 31, 2021, 12:01:28 pm »
I know I need a rev 2 arll board. The hard part is identifying the right one on ebay since it looks like I have to go by numbers written in marker on the PCB or get the resister values to make sure its the right one.
But the power brick is just an un regulated psu.
A multitap transformer, noise filter, bridge rectifier, and big capacitor.
Bank of fuses also.
If I read the schematics correctly the AR II board is doing all the heavy lifting.
So since I'd be building the cabinet from scratch and using a crt tv with component in and my own stuff for credits lights ECT. I really just need to get 10.6v dc and 36v ac to the arii board. Then it provides the main pcb with regulated voltages.
I just don't know how many amps are required.
The rectifier is fused on the input side with a 20 amp fuse so not sure on the 10.6 v amps
But the 36v output is fused with 4 amps.
Looking hard at schematic, I just need a Power filter, 36v transformer, and some fuses for the 36ac then a buck converter for the 10.6.
Not sure if the AR II two board cares if it gets its 10.6 dc power from an unregulated source or a switching psu though.
doubt it.
« Last Edit: August 31, 2021, 12:57:40 pm by nitrogen_widget »
