Author Topic: About to start painting and need advice..  (Read 2586 times)
darkomen64
  • Last login:April 29, 2012, 01:21:37 am
« on: October 19, 2008, 05:44:46 pm »
Ok i'm not really sure what kinda paint to use for both primer and main paint.. i'm guessing latex paint is the way to do for both.. but what color primer should i use.. my top coat is gonna be black... was thinking white primer might show though.. altho i'm gonna use 2-3 top coats so it should cover it just fine.. and i would like to use a different color then block for the primer because if you use a different color when you sand the fist top coat it'll show though on the peaks and such so you can get a better look in the final project..
Any suggestions.comments would help..
Also.. any real brands to avoid/use?
fatfingers
  • Last login:April 17, 2025, 05:26:08 pm
  • Got UltraStiks?™
Re: About to start painting and need advice..
« Reply #1 on: October 19, 2008, 07:26:22 pm »
Oil vs latex seems to be a bit like asking what the best front-end is.   >:D
Personally, I chose latex due to clean-up ease, and everything I did turned out just fine.  I suggest at least one layer of grey primer (white will work also), sanding in between each coat of primer and paint.  3 coats of paint should be good.  And I also suggest you use a foam roller as you will get the smoothest finish that way (unless, of course you're spraying).
Good luck.
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
W.W.P.M.D.?                                       I'm here to help ... I just don't do it. ™
darkomen64
« Reply #2 on: October 19, 2008, 11:08:30 pm »
thanks that was exactly the info i was looking for.. just 1 more question..
about how much of each should it take (2 coats primer 3 top)
1/2 gallon? whole gallon? .. i'm thinking a gallon but not exactly sure
mrclean
  • Last login:August 10, 2022, 08:30:36 am
  • World Record Holder for Gun Smoke Dedicated & MAME
    • Guscade
« Reply #3 on: October 20, 2008, 12:17:09 am »
I used spray primer / paint. Gray Primer.. And Gloss Black paint. I went to Home Depot they are about 2-3 bucks a can the company / brand was called rust-oleum painters touch.
2,370,650 Gun.Smoke
arzoo
  • Last login:January 26, 2025, 08:51:53 am
  • Robots WILL kill you.
    • LEDBlinky
« Reply #4 on: October 20, 2008, 09:01:43 am »
As a side note - most big home improvement stores (Home Depot, Lowes, etc.) won't even sell oil based paints anymore (due to environmental issues).
Robots will kill you.
Arcade Addiction
Necro
  • Last login:December 31, 2025, 03:36:17 pm
  • Building a 'Classic' MAME Cab
« Reply #5 on: October 20, 2008, 10:15:16 am »
Latex would be my suggestion as well.  With oil your going to need thinner and other harsh chemicals to clean brushes, etc.
Also, foam brushes work well and don't leave streaks.
fatfingers
  • Got UltraStiks?™
« Reply #6 on: October 20, 2008, 04:12:28 pm »
Probably 1/2 gallon of paint, maybe 3/4.
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
