Author Topic: Loose cd in laptop under the keyboard how hard will this be to remove??  (Read 1218 times)
divemaster127
  • Trade Count: (+60)
  • Last login:December 02, 2018, 08:05:08 pm
  • My webstore is arcadeemulator.net
    • arcadeemulator.net
Ok, my sister is one of these people if something has a problem its time to toss it & buy a another.  She gave me a HP 6000 series laptop amd dual core last week that  has issues.  I finally did a clean install & fixed everything but when i picked up the laptop & turned it sideways to put in the case.  I heard a clink pretty sure there is a loose cd under the keyboard.  How hard would it be to take apart the laptop to check.  I have built a ton of computers but I have always stayed away from laptops except for memory etc.  This is a extra laptop I want to fix & give to my son for school hes 13.
dm
I carry both ultimarc & happ items, all brand new & I ship from the united states. My online store is ARCADEEMULATOR.NET, pm if I can help in anyway.
Re: Loose cd in laptop under the keyboard how hard will this be to remove??
« Reply #1 on: October 15, 2008, 11:00:58 am »
Open case remove CD close case.
I'll be surprised if it's a CD.
divemaster127
« Reply #2 on: October 15, 2008, 11:05:16 am »
I tried that there is nothing in the cd case.  I can see a small cd sized opening at the top of the optical drive where a cd could slip thru into the main keyboard area if the cd/dvd was not locked down.  I have turned the laptop from side to side several times I can feel & hear the cd going from end to end hitting the sides
dm
« Reply #3 on: October 15, 2008, 11:19:25 am »
I meant the laptop case.
divemaster127
« Reply #4 on: October 15, 2008, 11:21:45 am »
ok, I will give that a shot
ark_ader
  • I glow in the dark.
« Reply #5 on: October 15, 2008, 03:21:15 pm »
While you are at it, give it a real good shake.
Also look at the screws, as you might need to remove them if the shaking doesn't work.  ;D
testicle187
  • Last login:April 10, 2025, 05:29:07 pm
« Reply #6 on: October 15, 2008, 10:56:37 pm »
Couldn't you just remove the one screw that holds in the optical drive, pull the drive out, and then tilt the laptop if it slides that easily?
somunny
  • Is it hot in here?
« Reply #7 on: October 16, 2008, 12:28:23 am »
Laptop keyboards are usually pretty easy to pop off.  Look to see if there are any tabs holding it on.
protokatie
« Reply #8 on: October 16, 2008, 12:47:05 am »
Just what I was going to say. There is one (1) screw that holds the optical drive in place in a laptop. Also, after removing it, you can get a somewhat decent look inside.
Outside of that, taking apart a laptop can be a pain in the ass, so do what you can to avoid doing that.
protokatie
« Reply #9 on: October 16, 2008, 12:54:24 am »
Sorry for the double post.
On SOME laptops the keyboard is easy to remove, but even if it is, there is often a layer in between the keyboard and the motherboard.
Laptops scare me. I will willingly help someone deal with their PC any day... unless it is a laptop. They are like a puzzle box, and if you drop a piece, the game is over...
