Author Topic: Nvts’s mountain’s Jukebox (revealed!)  (Read 18800 times)
Nvts
  • Last login:September 15, 2010, 02:30:14 pm
I haven't been working on mine all that much, but I have been looking into getting a panel for the back.  Would the 1/8 pressed pegboard panel that I used for the shell be sturdy enough to do the back panel?  the thinnest wood / MDF I can find is 1/4, and I would like the t-molding to work like Mountains did.
"A common mistake that people make when trying to design something completely foolproof was to underestimate the ingenuity of complete fools."
MameDownUnder
  • Last login:October 31, 2010, 03:46:23 pm
    • Mamer DownUnder
im making something similar to mountains as well, although mine is alot bigger as i have a 19" screen sub and 2 speakers
my question is what are you using for the grill at the front? im a little stuck as to what to use?
Cheers
Im thinking of doing the same for the back on mine. I have 1/8" hardwood that I plan to double up for the skin. I may double it for the back too, make it a 1/4" thick.
Im also planning to laminate it like javeryh did on his, so that should make it a lot stronger.
Im hoping one 1/8" piece with the laminate will be strong enough.
Nvts
I ended up finding some 1/8th plywood for the back, and I am still working on it, but I have a little more progress finally.
I went with a 1/4 frame for the speaker grill.  I didn't bother with the metal mesh, as I don't like how they look as much as plain speaker cloth.
I used some speaker cloth and some spray adhesive that I had to cover the frame and used a couple carpet tacks to hold it onto the panel a little better, though I doubt it would have moved.
I then mounted the glass
Followed by the rest of the screen, and the motherboard spaced from it as I tested earlier.
I have the front ready to go other than artwork.  Really wish I was better at that stuff so I could have gotten that out of the way as well before assembling it, but oh well.  I'll likely change it once the GF sees it anyway, right? ;)
I do notice that the screen opening is just a little bit too big, and you can see a little of the silver strip along the edges.  ah well.
The money shot.
I'm working on something for the back panel as well before I mount the shell to it that should be really snazzy.
To Do list
Figure out what parts to get and order a FrontX panel
Finish back of shell to handle back panel idea.
Mount front panel to shell.
add laminate
Make Tmolding slot
Add fan
Add  speakers
Add light
Add light box
Add slots for USB connections on the side
Find a copy of XP and reformat new drive and hope the IDE <=> SATA adapter I found works
Mount HD
Try to understand how to replace the start button, make an external speaker switch, power stuff, and other assorted wiring.
Make heat vents like drawfull did on his. (wish I had a router template tool like he showed...)
Finish marquee
Mount back
Work on software
15 other things I forgot.
Looking great NVTS!
I didnt know the glass would come off the monitor like that.
Nvts
From what I understand it should be stuck with some sort of double sided tape type stuff.  Mine was never all that stuck, though it has a strip of something between the glass and the screen.
drawfull
The one we used came from rutlands
http://www.rutlands.co.uk/cgi-bin/psProdDet.cgi/VARIJIG
Looks great nvts by he way!
Nvts
I played around in Gimp and posted a prelim marquee, if anyone has any suggestions.
edge
  • Last login:May 08, 2025, 09:08:47 am
  • AttractMode and GroovyArcade rock!
Re: Nvts’s mountain’s Jukebox (12/5 Pics. 12/6 Marquee feedback)
« Reply #48 on: December 09, 2008, 05:16:02 pm »
nvts - have you taken apart your speakers yet?  I am curious as to how you will relocate the volume knob?
I am (as is everyone else on this board) looking to create another mountain/nvts/drawfull/oldman/etc clone and am struggling on the speakers.  I want it to sound good on its own (so no soundbar) and want to have it flush against the front grille (ie, challenging with knob).
Keep up the great work.
Edge
Martijn
  • Akira!
    • ModMyBox
« Reply #49 on: December 10, 2008, 04:09:57 am »
Edge
my thought on this for my project is to have a small logitech x240 set.
Its a 2.1 system with a small sub what sounds nice.
I will put the woofer on the bottom, and put the pipe to the back
take apart the speakers
open up the audio control and replace the pot for audio control and just place it where everybody has the audio control knob
also the subwoofer level control will be in the back
dont know if it will fit, i just commenced building the clone
drawfull
« Reply #50 on: December 10, 2008, 08:28:54 am »
Edge
We used a speaker set with separate volume control on a flying lead, which was straightforward. We had to extend the spindle of the subwoofer volume by a few inches thoughfor the knob to reach the rear of the base. See this post in my thread for pics
Nvts
« Reply #51 on: December 10, 2008, 01:26:49 pm »
I'm using these klipsch speakers.  (damn, they are on sale for $60 now...)  I have them hooked up to my ipod now, and they sound wonderful.  Goodly amounts of bass for a set without a subwoofer.  When they lose power, they will turn off.  when the power comes back on, you have to push the knob to turn them on.  When they turn on, they are at a very low volume and you have to turn them up.   Oh, and it sounds like a normal crappy 2 inch speaker when the front is pulled off from the body.  :P
 I pulled them apart to take a peek inside, and the volume knob/led are mounted on a tiny circuit board. The other end is hooked up into an 8x2 connector that slides right out (Looks like its a 16-Pin Edge Connector, yes?  didn't see one on the Radio shack site.  Would hate to have to order one )  and extend the whole board up where I expected the powermate board to go.  Unless someone can make a suggestion how to make the powermate work, I think I might just use it on my computer, and find a replacement knob.  Perhaps I can make a plexiglass one.   :-\
You could easily use them and extend the knob and have the volume on the bottom.  the front of the speakers are almost flat up and down ( they curve about 1/4 an inch like this \_____/. I thought they were indeed flat before I put it against the table.) and they have quite the curve side to side, but the volume is in the middle so it wouldn't be an issue at all.  When I find a edge connector thingie, I'll see how easy it is to extend the cable and let you know.
Re: Nvts’s mountain’s Jukebox (12/10 Speaker guts pics)
« Reply #52 on: December 10, 2008, 04:25:47 pm »
Looking good nvts!
You might extend those wires by cutting them and soldering in an ide cable between the two cut pieces, or since there are eight wires, a cat-5e Ethernet cable may work. That would be a lot neater and take up less space.
Im worried about my powermate too.
I can fall back on a regular pot if need be. But Im quickly running out of time, so for now if it doesnt work, wife will have to cycle juke on and off. May have to install a regular pot after Christmas.
Im looking at that volume board you have, and it looks like it is just a pot with an led.
You might could use just a regular pot too, just measure the resistance on the pot on the board and buy a audio stereo pot the same value. Just a thought.
Nvts
« Reply #53 on: December 10, 2008, 04:48:55 pm »
I actually think it will be easier than that.  I think all I have to do is get a 16 pin connector and a piece of 10 wire flat ribbon cable and make an extension.  The socket slipped right out of the master board on the other side.
If that connector fits on the other board, it's actually an easy, cheap solution...  I would need to slice a small hole in the bottom of the speaker for the ribbon.
I wouldn't use the powermate, so I would just have to find a big snazzy knob to use instead.  I'll pick up a connector tonight, and try to get it to work tomorrow.   Right now, I am trying to figure out out how to add a SATA drive to my IDE only system.  it's not liking the converter that I have, so it does not recognize the drive.
« Reply #54 on: December 10, 2008, 08:55:59 pm »
That sounds like a better idea.
Can you use an IDE cable? You can pull apart all the wires but 10. Just make sure it is the older 40 wire IDE cable, not the newer 80 wire. (40 wire is bigger gauge, I think.)
I have some old ones lying around I can send you, if you want.
Not sure about your sata problem, thats why I didnt go with a sata drive, since my MB doesnt have sata. Did the adapter come with any software drivers? Maybe you need to google the adapter model and see if others have fixed it.
mpm32
  • Cheesecake Master
  • Last login:November 20, 2018, 09:25:14 pm
« Reply #55 on: December 11, 2008, 11:26:46 am »
Are you going to mount the speakers without the cabinet backs?  If so, you should try them out, all that bass you talked about will most likely be gone without the entire plastic cabinet, which is where they get the bass when using the small drivers.
Nvts
« Reply #56 on: December 12, 2008, 05:55:12 pm »
Nah, I'm going to leave the speakers as they naturally are, other than the volume knob extension.
Picked up some 16 pin edge connectors, and a 16 wire ribbon wire and  a couple packages of D-sub crimp shell contacts male ( ) and went about making the ribbon cable.  I don't have what I assume are proper tools to crimp the ribbon cables together, and I ended up braking one of the edge connectors, so I'll have to pick another one up.  I can't seem to find any male edge connectors, so I made a couple of 2 inch wires with a contact on each side for the gender change.
I'll pick another connector Monday.  If I do get any more time until then, I can keep working on the back panel.
The plan will indeed work though, I'm fairly sure.  I was able to test for continuity between the pins that were working, and the board.
« Last Edit: December 12, 2008, 07:08:43 pm by Nvts »
« Reply #57 on: December 13, 2008, 11:08:34 am »
Could you solder those connectors instead of crimping them?
I know they can be a real pain even if you have the proper crimping tool.
Nvts
« Reply #58 on: December 13, 2008, 04:24:18 pm »
eh, no worries, it can wait till Monday till I get a new end.  They are cheap.
Today, I got the rear panel working almost as well as I could want.  I did not want to have visible hinges, so I tried out a hidden hinge.
I cut out the panel and a door from my 1/8 plywood.
I put a 1/4 MDF behind the door, and laminated the whole back panel.  I trimmed the door to 1/4 inch with a dremmel cutoff wheel, a dremmel sander block, and a metal bar.
When I made my mock up with 1/2 inch mdf, it all seemed like it was going to work great, but I ended up needing 3/4 of an inch, so I rigged up a thicker door.  Installed the hinges to a 1 1/2 inch board that was screwed and glued to the frame.
I added another 1 1/2 board (and a extra bit...) to the other side for a double magnet catch.
Door guts:
I temporarily mounted the back panel to do the rough adjustments. It's a little rough, and I'll need to fine tune it once the back is attached the the shell, since the back panel is a bit warped and not cooperating properly.   It almost works great though. almost.
I have a feeling that I will just make a new cleaner looking door once time permits, but I am worried about the deadline.
« Last Edit: December 13, 2008, 04:28:23 pm by Nvts »
Nvts
Re: Nvts’s mountain’s Jukebox (12/13 Rear panel and door pics)
« Reply #59 on: December 18, 2008, 02:00:30 pm »
I had glued and screwed the front panel to the shell, and found a few things that made me end up ripping the screen and speaker grill out.  Since I didn't keep the inside shell the same width as the front panel shell, this was a whole lot of work.  :p  I was planning to have the screen held down with a metal strap that was screwed between the two parts.  It worked really well, and the screen was much more solid, but it got some dust inside of the screen, and I knew that it would drive me nuts.
I also got the volume knob relocated and working wonderfully.  i used those little pins next to the wires to make the swap over.
Stuck it up where it would go.
The little board next to the volume control slides over and wedges the board into place without having to worry about mounting the control board itself to anything.  the pot does not have a screw on part like a powermate.
I tried to use the powermate knob on it, and the plastic spacer fits over the LED perfectly.  I now can have the glowie effects of the volume control.  it's not as snazzy as the powermate ones, but its still kind of cool.
It seems a waste to get a powermate just for the knob, and not even the guts, so I sent Griffen an email asking if I could buy the knob and plastic spacer, and they said no.  :cry:  Anyone have an extra pair of parts, by chance? :p
Next up, rebuild the speaker grill, and remount the screen and innards.
mountain
  • Trade Count: (+9)
  • Last login:January 29, 2025, 08:31:47 am
    • Mountain Jukeboxes
Re: Nvts’s mountain’s Jukebox (12/18 pics)
« Reply #60 on: December 18, 2008, 03:18:24 pm »
Lookin' good  :cheers:
I found a big aluminum knob on ebay that may work for you here.
Martijn
  • Akira!
    • ModMyBox
« Reply #61 on: December 18, 2008, 04:21:13 pm »
good find mountain, but just not nice enough to replace the powermate.
The little screw hole really does it  :'(
mountain
  • Trade Count: (+9)
« Reply #62 on: December 18, 2008, 05:02:02 pm »
Have a look at these then.  ;)
example 1
example 2
example 3
example 4
example 5
example 6
facesmiths
  • Last login:April 10, 2011, 07:53:05 pm
  • nemo goggles
    • Borg Steam Factory
« Reply #63 on: December 18, 2008, 06:17:09 pm »
are you going to mount that computer on the back of your monitor? I don't know about the elo units but my krystal units get kinda warm so I would keep a little distance between the two. at the very least use some aluminum spacers and a bit of longer bolts. this would ofcourse give room to mount some sort of cooling system to pull air from between them and maybe add to the other fans on the units effectiveness. just my two cents. I'm going to go back to reading the rest of the thread :D
Nvts
« Reply #64 on: December 18, 2008, 07:23:54 pm »
I have a couple nuts for spacers between the two, so the distance would be about 1/2 an inch.  I will also have a fan underneath, pushing air upwards and out the top.  Would this be enough, or should I add some extra space in there?  Is there anything else that I could do to make sure that it stays cool enough?
on an aside, I never thought that ebay has an entire section for knobs.   :P
Nvts
« Reply #65 on: December 18, 2008, 09:02:29 pm »
Managed to get the laminate on today before I had to pack it up.
I laid the sheet on the ground, and put a piece of painters tape over where the line would be.  I made a line on the tape, then taped a straight edge on it and scored it a few times with a utility blade.  I then used some scissors and cut it like I had been.  However, it worked much better this time.  :p
I had a hell of a time getting the first two layers onto the shell properly, so I knew I wanted to do the laminate better.  I put a spacer under the shell, and glued it up, then pulled both ends around the curved part at the same time towards the bottom, then used the J roller and got it all stuck.  It worked so much better then trying to start at one end and get it straight.
Concept test
Glued
I know I don't need to weight it down, but I cant help it...
Martijn
  • Akira!
    • ModMyBox
Re: Nvts’s mountain’s Jukebox (12/18 laminate pics)
« Reply #66 on: December 19, 2008, 02:42:12 am »
Franco B
« Reply #67 on: December 19, 2008, 04:33:24 am »
She's really taking shape now :)
I could make you a nice knob (oo-er  :laugh:) if you like.
« Reply #68 on: December 19, 2008, 05:32:42 am »
Good job Nvts! She's really starting to take shape now.
You beat me to the idea of the led shining through to the bottom of the volume knob.
I'm trying to do that with the powermate.
I still dont have a warm fuzzy feeling about the powermate.
I sure hope the monitor doesnt run hot, Im mounting my motherboard the same way.
I dont see any vent holes in the very back of the monitor, and there will be a plate between it and the motherboard, so Im sure hoping it will be ok.
Keep up the good work. Maybe when we are all done with these jukes we can have a "Mountain jukebox copy team" party.  :laugh:
Nvts
« Reply #69 on: December 19, 2008, 10:36:14 am »
I'm setting up to flush trim the laminate and I am apprehensive that I will scratch it with the router.  Is there something I should do special, or would it not be an issue if its smooth?  I'll tape the front panel to try to not get a devastating scratch like javeryh had.  Never mind, I went ahead and cleaned everything off really good, and had no issues at all.
Perhaps try to put a aluminum foil / mirror like surface behind the board and make the hole up to the knob wider so that light can get out.
I stuck a mini dvd into a cup and held the powermate about half an inch above the DVD, and it seemed like it would get a nice glow upwards.  I would imagine making the spacer out of clear plexi would help (mountains pic)
Perhaps after the holidays and I can get some feedback. I'll use the powermate one for now, but I would really like to just use it on my desk instead since I dont need the guts anymore.
I have a thought of what might work and look really nice.  Stack a couple layers of clear plexiglass up and drill out the hole and flat edge to hold the pot.  Then mill a knob that fits around that so that you have a lighted center, something like this in concept, but in a volume knob format  :D
The other thought is using that plastic that bends light out to the edge, and using that is the bottom layer, and milling something over that.  that would make a knob that works like a powermate.
« Last Edit: December 19, 2008, 12:58:25 pm by Nvts »
« Reply #70 on: December 19, 2008, 06:23:58 pm »
I have already cut out some clear plexi for the PM to mount to.
I drilled the hole in a square of plexi and fastened a 3/8" bolt to it.
I then chucked the bolt in a drill and ran it against a belt sander. I had to take it easy and measure a few times until I got the 1-5/8" diameter in the clear plexi.
I drilled my hole wider (1-1/2") than the round circuit board on the PM.
Im planning on putting a mirror behind the PM to reflect the light from the blue led around the PM guts to the front plexi.
Looks like we had the same idea. Great minds think alike.
Nvts
« Reply #71 on: December 19, 2008, 10:04:43 pm »
I'm getting ready to cut the Tmolding slot, and I noticed that Mountain cut his to 1/4, which is the depth of the Tmolding part.  I notice that the set that I got using a bearing that makes a 1/2 cut, which is default, I guess.   I can go halfway across town to get a larger bearing (1-3/8" Outside D x 5/16" Inside D) for $15.  I'm running out of time, and money, so I was expecting to use the router table fence to set the cutting depth.  Is that as easy as it sounds, or would it be wise of me to get the extra bearing?  Is the difference between the default 1/2 cut and the 1/4 cut worth bothering over?  I know on a arcade machine, there is loads of extra wood, but these things are flimsy.
mountain
  • Trade Count: (+9)
Re: Nvts’s mountain’s Jukebox (t molding question)
« Reply #72 on: December 19, 2008, 10:28:07 pm »
Make a mark on you're blade with a Sharpie that represents 1/4". Turn on your router (assuming that it is mounted upside down on a table) The mark will make make a faint circle as it spins. Touch the Sharpie to the mark on the blade, as it is running. Then just eyeball it and take your time. This is what I did.
If you don't do this, the wood may split as you hammer the T-molding in.
« Reply #73 on: December 20, 2008, 05:29:54 pm »
I used your method of marking the depth on the slot bit and it worked great. Thanks Mountain!!
Nvts
« Reply #74 on: December 20, 2008, 05:53:31 pm »
Here is my preliminary slot location test.  It looks like the molding fits right exactly on the edge, but I want it just a smidgen closer to the edge so that the edge of the tmolding will grab the front and back a tiny bit, right?
That new bit was so sharp that I didn't even feel it cutting into the test board.... :o
« Last Edit: December 20, 2008, 07:38:38 pm by Nvts »
Nvts
Re: Nvts’s mountain’s Jukebox (t molding test pic)
« Reply #75 on: December 21, 2008, 07:55:59 pm »
I had some issues with my router table not being quite big enough for keeping the shell straight enough.  I kind of messed up a little on the front side, and pulled the router out of the table for the back.  The back went way better.
So I am putting stuff together, and I decide to do a demo test, and the touch screen does not work now.  I'm not sure what happened.  If i touch the metal tabs in the very corner, I can make the pointer jump around, so I don't think it's a connection issue.  How do these things tell where my finger is?
mountain
  • Trade Count: (+9)
Re: Nvts’s mountain’s Jukebox (Screen not working!)
« Reply #76 on: December 21, 2008, 08:08:50 pm »
Make sure nothing is touching the diagonal lines around the edges of the touch overlay. They are SAW (Surface Acousical Wave) technology. Anything touching them will throw it off. I am pretty sure this is your problem if the unit worked before mounting it.
Nvts
« Reply #77 on: December 21, 2008, 09:09:01 pm »
I pulled the monitor back out, and cleaned off the screen and I still get nothing.  I did have some weatherstripping on the glass and removed it, but I still get nothing.  Hope i didn't hose the screen up.  :banghead:
« Reply #78 on: December 21, 2008, 09:12:56 pm »
I just hooked mine up for a test run and had the same problem.
I had to remove the foam rubber weatherstripping I had put around the edge of the monitor opening in the acrylic.
It was touching the lines Mountain talked about.
I removed the weatherstripping and now it works good.
I wish I could easily remove the acrylic and make another one. I would extend the edge of the acrylic about another 1/2" all the way around the monitor, I think that would allow me to use the weatherstripping. It looks a lot better with the weatherstripping filling the gap between the monitor glass and the acrylic. Plus if I could re-do the acrylic, I could fix that one corner I screwed up.
Oh well..
« Reply #79 on: December 21, 2008, 09:15:09 pm »
I think I posted about the same time as you.
So nothing is touching the glass and it's still not working?
You had the glass off the monitor, didn't you?
Do you think you might have a plug loose between the glass and the monitor works?
