Author Topic: VGA to SCART lead  (Read 3659 times)
MarcC
  • Last login:February 22, 2010, 10:02:16 am
VGA to SCART lead
« on: October 03, 2008, 04:51:26 pm »
Could anyone help me here?
I have tried to make my own but its just way too hard too do.
Is there anywhere in the UK that would sell this kind of cable please?
Thank you
sham69
  • Last login:June 12, 2015, 06:03:44 am
Re: VGA to SCART lead
« Reply #1 on: October 07, 2008, 04:02:37 am »
Hi,
I have just ordered one from Germany as recommended by Sailorsat.
It should be arriving today or tomorrow so once I test it I will report back and give you the link.
MarcC
« Reply #2 on: October 07, 2008, 04:30:32 am »
Ah brilliant thanks alot for that!
One of the members on here kindly offered to make me one and I should be recieving this early next week.
But let me know how you get one, its always good to have a back up
Zebidee
  • Last login:February 16, 2026, 01:21:22 pm
« Reply #3 on: October 10, 2008, 11:46:45 am »
Here is your VGA->SCART lead being tested on my 33" Grundig:
redhorse
  • Last login:October 08, 2013, 03:08:28 pm
« Reply #4 on: November 12, 2008, 12:46:23 pm »
Hi,
I'm also looking for a vga to scart cable, can you tell me where you've ordered them in Germany?
Avenger Squadron
Tie Fighter Alliance (http://darkjedi.org/club/TFA)
Dark Jedi Organization (http://darkjedi.org)
Zebidee
« Reply #5 on: November 12, 2008, 04:20:06 pm »
Hi, if the supplier from Germany doesn't work out then PM me I could make you one at a very reasonable price (especially now the Aust. dollar has fallen), like I did for MarcC.
Joey Butafuko
  • Last login:January 13, 2012, 04:59:19 pm
Zebidee
« Reply #7 on: November 14, 2008, 07:47:37 pm »
Assuming they used the resistor method, that German cable won't work if your video card doesn't output 5v on VGA pin 9 - I think ATI cards are the only ones that do.  Also, it might not switch to AV mode properly for you as 5v is technically too low for 4:3 AV, but this depends upon your TV and it's quirks.
« Last Edit: November 14, 2008, 07:56:10 pm by Zebidee »
redhorse
« Reply #8 on: November 17, 2008, 03:00:46 am »
I had an email conversation with the seller of the German cable and he told me that there is a USB connector that can be used to get the 5V.
However my concern is also that the 5V is not enough to get the TV to 4:3 AV.
Although my TV is a 4:3 TV and not a 16:9, is it still possible that 5V are too low?
Zebidee, did you receive my PM?
Avenger Squadron
Zebidee
« Reply #9 on: November 19, 2008, 11:10:11 pm »
Sorry for the late reply.  I didn't get your PM?  Don't know why.
In my experience, some TVs need more than 5v, some don't.  You might get lucky. You would have to test each one to be sure.  But the technical specs say that the 4:3 AV mode switching signal to pin 8 should be in the range 9.5v - 12v, and 5v is simply lower than that so what more can I say.
That is why, when I make a full-on VGA-SCART cable, I always add on a standard 4-way PC molex power connector to supply:
*   5v (the red wire), stepped down by 100ohm resistor to about 2v, to pin 16 (triggering RGB mode).
*   12v (the yellow wire) direct to pin 8 (triggering 4:3 AV mode).
*   DC Power supply grounds (the 2 black wires) to pin 18, to make sure all is safe.
