Author Topic: Installing a Chassis...any suggestions appreciated  (Read 1261 times)
SnotRockit
  • Last login:October 07, 2008, 08:00:11 pm
  • Stickin' with the classics!
    • A.J.'s Place
« on: October 02, 2008, 11:11:51 pm »
I have an old Electrohome 19" monitor that I bought a working chassis (G07) for. I am about to install it and since I am a total "newbie" at this, I'm worried about killing the new chassis, tube, game PCB...(and ME!).
Is there any particular steps I should take? I was planning on doing the following...
 1)   discharging the tube again
 2)   connecting the chassis to the frame
 3)   connecting the anode? (the suction cup thing)
 4)   connect the back thing that connects to the vaccum tube at the back (see, I AM a newbie)  :)
  5)  connect the power cable
The only thing I wouldn't yet connect is the connector cable (that allows the data to flow between the chassis and the PCB.  Am/Should I (be) able to turn on the power to see if in fact the tube with chassis is working? What should I see if it's working?
Any assistance is GREATLY appreciated. Thanks.
SnotRockit
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
Re: Installing a Chassis...any suggestions appreciated
« Reply #1 on: October 02, 2008, 11:27:52 pm »
personally , i'd slightly adjust the order.
2>1
1>2
isolation xformer  ?
with no sig , u may ( likely not ) have a lit screen . as long as the iso xformer ( if needed) is connected to the
monitor , there shouldn't be a problem connecting the video  .....
no need to fear electricity , yet one MUST respect it .
qrz
Ken Layton
  • Guru
  • Technician
« Reply #2 on: October 03, 2008, 12:11:33 am »
Don't forget to plug in the yoke cable! Same for the degausser cable.
qrz
« Reply #3 on: October 03, 2008, 06:41:19 pm »
well that was a given .....but, still a good reminder for the inexperienced.
of course, connecting the yoke is far more critical than the degaussing coil.....
qrz
