Author Topic: Picked up a new cab to MAME!  (Read 4150 times)
beerbarrel
  • Last login:October 18, 2025, 07:00:48 am
« on: September 28, 2008, 10:30:27 am »
Went up to Atlanta yesterday and picked up this Dynamo cab with Tekken 4. The cab has a few bad areas but I think that they will be repairable. I don't know if it has the original monitor but it has an absolutely beautiful picture. The monitor itself is super clean. It almost looks new. It is a Samsung 25 incher. It is a blue formica. The game was bought in a non working condition but has been working ever since it got to its new home. I don't really like fighting games but I will let the kiddos wear it out for awhile before the crap comes out and the good stuff goes in. Here are a few bad pic but you get the idea. What do u guys think? A good pickup for Mame?
Tracy
Havok
Re: Picked up a new cab to MAME!
« Reply #1 on: September 28, 2008, 10:32:20 am »
Perfect Mame candidate. Congrats on a good score. It's got a great screen, and excellent control panel size for modification.
Ginsu Victim
  • Comanche, OK -- USA
« Reply #2 on: September 28, 2008, 11:04:16 am »
Hell yeah. Great score. I'm jealous.
beerbarrel
« Reply #3 on: September 28, 2008, 05:32:43 pm »
Thanks guys...I was pretty proud of myself at that. Now, I have to figure out what to do with the outside. Should I try to repair the Formica or bondo areas and paint the cab. Anyone ever paint formica? How does it do?
Tracy
  • Last login:February 04, 2026, 05:27:25 pm
« Reply #4 on: September 28, 2008, 05:45:47 pm »
Tracy
I've painted Formica. It's fine. If you try to pull it off, you'll have a mess of glue to deal with.
Havok
« Reply #5 on: September 28, 2008, 05:49:51 pm »
Scuff the surface of the cab with a fine grade sandpaper, bondo what needs to be repaired, and paint. That way the paint has a place to adhere to. If you just paint over it, the paint is much easier to take off, whether you want it off or not.
beerbarrel
« Reply #6 on: September 28, 2008, 06:06:02 pm »
Do u just fill the areas that are missing formica with bondo or do u replace with new formica? If it sands well I'm going to fill and paint. I also thought about contact paper in black. You guys tried that? I will have to remke a couple of small sections of the cab because they are busted. Thanks guys...
Tracy
Flake
  • Last login:January 11, 2025, 01:16:20 pm
  • I am Evil Homer....I am Evil Homer....
« Reply #7 on: September 28, 2008, 09:13:07 pm »
You shouldnt have any problems removing the formica if you use a heat gun ($20 from Lowes).  I have also read where people have used a hairdryer.  This process loosens the glue and the formice just comes right off.  Once you have this off get a orbital sander and using fine grit sandpaper sand the whole thing down.  Then bondo the imperfections - make sure you do this in a ventilated areas as the stuff really stinks.  Bondo is fairly easy to use but it will start to set within 5 minutes or so depending on how well you mix it.   Once you have bondo'd up everything go ahead and resand everything again.  Once it was sanded I used a spray gun to apply the paint.
Overall, its a relatively easy process to fix up the exterior is you dont like the way it currently looks.  This is the process I went through.  It takes a little bit of time but honestly it looks like it came off an assembly line.
Good luck
Kajoq
  • Last login:June 14, 2024, 11:28:46 pm
« Reply #8 on: September 28, 2008, 09:23:36 pm »
Where in Atlanta did you stumble upon that?  I'm going down in a couple weeks to visit my parents/go to a Street Fighter Tourney and  I've been sort of trying to convince my dad to snag a cab for me to screw with when i go back home.
Go Jackets!
beerbarrel
« Reply #9 on: September 29, 2008, 10:51:16 am »
It's kind of a long story, but I picked it up from a guy in Marietta that lives off of the square. I saw that he had a Defender coctail on Ebay that did not sell. I sent him an email about it and he said that it was still available and to give him a call. I did just taht and when I went to get it he had others just sitting around in a warehouse. Next thing you know I had it.  :cheers:
Go Jackets!
beerbarrel
« Reply #10 on: September 29, 2008, 10:52:27 am »
You paint right over the particle board?
Good luck
Todd H
  • Last login:August 26, 2024, 02:23:32 pm
  • It's Gameday!
« Reply #11 on: September 29, 2008, 11:09:48 am »
I think I'm jealous. I've been looking for a cabinet to MAME in Georgia forever. I still haven't found what I'm looking for. Where is the best place to look around Atlanta?
beerbarrel
« Reply #12 on: September 29, 2008, 11:18:53 am »
Contact ebay seller    (david.countryman) it is where I got mine and I'm sure he can hook you up. I think he posts his # on ebay ads.
Tracy
Todd H
  • It's Gameday!
« Reply #13 on: September 29, 2008, 11:20:21 am »
Much appreciated. :)
Visitor Q
  • Last login:May 01, 2019, 09:09:30 am
  • The Saw Is Family
« Reply #14 on: September 29, 2008, 11:43:11 am »
Looks nice but the price is what would be the biggest factor for me.
“Woe be unto him who opens one of the seven gateways to hell, because through that gateway evil will invade the world."
beerbarrel
« Reply #15 on: September 29, 2008, 11:44:18 am »
250....working
Flake
« Reply #16 on: September 29, 2008, 12:26:22 pm »
Good luck
Well the cabinet I used was a Killer Instinct cabinet and pretty sure it was MDF.  I know its not particle board.  I would bet yours in the same.  After you have it sanded and bondo'd I would apply a layer or two or primer but yea after that just paint right onto the wood.  If you have it sanded well enough (orital sander is a big help) it will look great.
Here are some pics of my cabinet prior to adding the CP to give you some perspective.
Jack Burton
« Reply #17 on: September 29, 2008, 04:09:28 pm »
Damn, that is my favorite all time cabinet design.  Street Fighter players like me would kill for one those cabinets.  You could probably easily sell it if you posted it on shoryuken.com
Seeing it modified and turned to MAME lets me feel the same way that most guys do on here when someone puts SF2 in a Defender cabinet.
Ummon
  • Trade Count: (+13)
« Reply #18 on: September 29, 2008, 10:56:03 pm »
Tekken 4 uses a VGA monitor doesn't it? Or it might be a tri-sync.
Yo. Chocolate.
Stephen Hawking
Jack Burton
« Reply #19 on: September 29, 2008, 11:40:52 pm »
Well, it's a conversion to Tekken 4, so it might just be set in 15khz mode.   I doubt they would change monitors unless they had to. It was originally a capcom cabinet, seen here:
http://www.arcadeflyers.com/?page=flyer&db=videodb&id=1148&image=1
or perhaps more specifically it might have been one of these:
http://www.arcadeflyers.com/?page=flyer&db=videodb&id=1148&image=2
since the marquee looks like those.
KDOG
  • Last login:September 18, 2020, 03:08:26 pm
« Reply #20 on: September 30, 2008, 12:38:55 am »
Check namco arcade used games. The list aren't very accurate just call to see if they have it and if any of the places are close to you go by and check them out.
http://www.namcoarcade.com/game-sales.asp
Also there is super auction coming up in Nov around the Atlanta area. They haven't set a location  but you can find a good deal there.
beerbarrel
« Reply #21 on: September 30, 2008, 03:47:36 am »
I know guys! It's hard to get a break. No matter what the cab, somebody does not want you to mame it. I figure that it has already been converted so I'm out of the woods there. It is not for sale because I like it. I gotta Mama one sooner or later so this is my guy! I was just wanting some general info on the cab. I got to Mame it.
 :banghead:
Tracy
Zeppo
  • Last login:February 14, 2024, 10:26:44 am
  • Greetings Program!
« Reply #22 on: September 30, 2008, 04:40:57 am »
Yep, that's exactly where that cabinets came from.
I was working at Dynamo when they first started producing those games for Capcom.
Z
Todd H
  • It's Gameday!
« Reply #23 on: September 30, 2008, 08:32:13 am »
 :banghead:
Tracy
I wouldn't worry about it and just MAME that sucker.
I sent the guy on eBay a message but he never replied. I'm going to keep trying.
DantheApe
« Reply #24 on: September 30, 2008, 09:13:57 am »
what are your plans for the game board(s) since it's obvious that the game works?
beerbarrel
« Reply #25 on: September 30, 2008, 10:40:26 am »
Have not thought about it too much. Right now, I'll let the kids wear it out until I get time to work on it. Need the MB?
DantheApe
« Reply #26 on: September 30, 2008, 10:44:32 am »
sent ya a pm
Jack Burton
« Reply #27 on: September 30, 2008, 01:37:50 pm »
Even though it hurts, I gotta agree, this is one of these best cabs ever made for MAMEification.  Nice big monitor, sturdy, huge control panel, great speakers, JAMMA, it's all already there.
I doubt you really could do better than it.  At $250, it's a dream compared to spending thousands on a custom built MAME cab.  Even in it's current state, you could slap a J-pac and PC in there for $100 and have one of the highest quality MAME cabs around.
*jealous*
beerbarrel
« Reply #28 on: October 01, 2008, 02:11:14 am »
Welp, I found out something new about this cab. It is not formica at all. It is Melamine MDF. I guess that is more like a thin PVC covering. I'm assuming that it paints like Formica. I'll give it a shot and see what happens.
Ummon
« Reply #29 on: October 01, 2008, 10:15:52 pm »
Street Fighter II is sprite graphics - 384x224. Tekken 4 is 3D graphics and runs at 640x480. Unless the monitor is a multisync, it was switched.
« Last Edit: October 03, 2008, 08:34:26 pm by Ummon »
Yo. Chocolate.
Stephen Hawking
beerbarrel
« Reply #30 on: October 02, 2008, 02:26:02 am »
So what does that mean for me if I want to run mostly CGA games? Monitor still usable?
Street Fighter II is a raster game - 384x224. Tekken 4 is a 3D game and runs at 640x480. Unless the monitor is a multisync, it was switched.
Ummon
« Reply #31 on: October 03, 2008, 07:27:17 pm »
You can do two things:
- you can go ahead and run them and see if it syncs or shuts down
or
- you can try to identify the monitor and find its specs.
Yo. Chocolate.
Stephen Hawking
beerbarrel
« Reply #32 on: October 03, 2008, 07:41:47 pm »
I need to pull that heavy Bas... out from the wall and have a look I guess...thanks!
Jack Burton
« Reply #33 on: October 10, 2008, 04:25:39 am »
I'm just gonna chime in here and say that even if this is a 31khz only monitor, you will still be able to display low and medium res games on that monitor in MAME.  It will simply scale the image up in the same way as if you were to play the game on your PC monitor at 640x480.
So no worries if you were thinking you will have to get a new monitor to play all the games you wanted.
« Last Edit: October 10, 2008, 04:27:25 am by Jack Burton »
