Author Topic: Sanyo 20EZ B+ pot identify  (Read 4860 times)
cornishHen
  • Last login:February 08, 2016, 08:32:23 pm
« on: September 24, 2008, 08:32:10 pm »
I've been trying to figure out a video problem with a dk (2 board) boardset and a Sanyo 20 EZ.  I decided to cover my bases in troubleshooting the problem today and checked the B+ voltage on the Sanyo.   I found it was running on average at 91V...well below the desired 108V.  I tried to adjust the B+ pot and it seems the pot is toast.  It spins and has a small piece of metal bent/broken.
Can anyone help me identify the B+ pot/suitable replacement?  Also, the R-Drive pot is partially broken but appears to adjust the red intensity fine.  From what i'm seeing that pot is VR254 8ohm-200ohm?  I found Bob Roberts has a nice selection of pots at:
 http://arcadecontrols.com/BBBB/pots.html.
Thanks for any help!
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
Re: Sanyo 20EZ B+ pot identify
« Reply #1 on: September 24, 2008, 09:40:05 pm »
i'm not much help on this one.... :(
the print i found ( web) is a very poor copy . the b+ pot just happens to lie in the area missing . figures !  :hissy:
does anyone have a decent print, schematic link . or  a unit they could have a looksee ?
qrz
Kevin Mullins
    • Me on Myspace
« Reply #2 on: September 25, 2008, 01:36:00 am »
VR254 - 200 Ohm   (R-Drive)
VR601 - 5k Ohm     (B+)
Decent Schematic:
Sanyo 20EZV Schematic
There's a few more on ArcArc if you need those as well. Some slightly older versions, etc.
« Last Edit: September 25, 2008, 01:44:00 am by Kevin Mullins »
cornishHen
« Reply #3 on: September 25, 2008, 08:22:43 am »
Thanks for the help guys!   :cheers:
Placing an order with bob roberts today.
« Last Edit: September 25, 2008, 08:26:26 am by cornishHen »
qrz
« Reply #4 on: September 26, 2008, 12:47:09 pm »
much better copy  !
 tnx kevin  :cheers:
qrz
