Author Topic: Plexi Marquee with scratches in white area can i just use white paint to fix ?  (Read 1053 times)
mrclean
    • Guscade
Just got a marquee which is plexi and on the back of the art is slight hair line scratches in a white area.. can i use white paint for this ? or what's the best if any solution for fixing the imperfections on the back of a plexi marquee.
2,370,650 Gun.Smoke
TheShanMan
    • My Arcade (updated 1/30/13)
I don't know if there's a good solution, but I can tell you that painting those spots is NOT a good idea if it's going to be backlit. The paint you apply will be a different thickness (and probably a different translucency), making those spots obvious when backlit. I can tell you this from experience. :banghead: After that experience, all I've done is use appropriately colored sharpies. Not great, but better than nothing.
Xiaou2
  • Last login:Yesterday at 09:40:44 pm
  • NOM NOM NOM
Somewhat risky... but,
 Using a spray based paint (rather than brushing, which lays paint too thick)
sweep from several feet above, in even passes.    Coating the entire marquee
in a very thin mist of white paint.
