Author Topic: Commandline to light LED buttons? Does LEDBlinky support this?  (Read 1198 times)
Fat-Johnny
  • Last login:April 14, 2023, 09:23:33 am
« on: September 22, 2008, 04:13:04 pm »
I currently have my whole panel with LED buttons (GroovyGameGear’s RGB boards under GGG's Electric Ice buttons) driven by three GGG LED Wiz’s.  Basically, I have some PC games that I want to light certain buttons or trackballs for.
I run Mala with the LEDBlinky plugin for my MAME needs, but really have no need to set up PC games as an “emulator” in Mala.  Maybe I am just lazy………..
So is there any way, from the Windows XP desktop, to launch a game, but instead have it launch a .bat file that would send a commandline to LEDBlinky first, light the appropriate buttons/trackballs, then run the game??
Please keep in mind that I have three LEDWiz’s, so the solution has to support that.  I can easily go into Randy T’s “LumeAura” program, light certain things, then exit, but last I used it it only supported one LEDWiz.
Anybody got a commandline solution?  Does LEDBlinky already support this and I am just stupid?  What would the commandline syntax look like?
Please help!
FJ
arzoo
  • Last login:January 26, 2025, 08:51:53 am
  • Robots WILL kill you.
    • LEDBlinky
Re: Commandline to light LED buttons? Does LEDBlinky support this?
« Reply #1 on: September 23, 2008, 08:36:05 am »
Yes, LEDBlinky has a command line mode - check the readme.txt or help doc for a list of commands. But basically, you'll need to set up the profile for "other emulators", then just use this command:
  LEDBlinky.exe "name" "pcgame"
The parameters "name" and "pcgame" don't really matter unless you're going to define different layouts for different games.
As for "and I am just stupid?" - not for me to say  ;D
Post back if you have any questions.
Robots will kill you.
Arcade Addiction
