Author Topic: VPLaunch Visual Pinball Wrapper Command Arguments  (Read 5052 times)
XyloSesame
  • Last login:September 17, 2024, 05:57:04 pm
  • the creepy prince guy...
    • The Nightingale Theater
« on: September 19, 2008, 01:16:38 am »
VPLaunch works fine with tables in the default location, but I can't seem to get the wrapper to launch tables that are not in the default "Visual Pinball\Tables" directory.
I have my Executable set to vp-launch5.exe in the root Visual Pinball directory. My ROMS are in individual folders in a different directory which I have specified in MaLa's Rom Path (search subs checked).
If I use %path% with any combination of switches or %rom% settings, I get Runtime Error 52, Bad filename or number. If I use just %rom% with or without switches, the MaLa "starting" window flashes, but no application is called.
I've been able to find posts about this specific to MameWAH, but not MaLa -- what am I doing wrong?
