Author Topic: MAME SF3 cd loading  (Read 3742 times)
Banacek
  • Last login:November 08, 2017, 05:01:31 pm
MAME SF3 cd loading
« on: September 18, 2008, 05:39:02 pm »
This never seems to work for me. The loading screen comes up and it just sits there doing nothing. Does this happen to anyone else? Thanks.
Ginsu Victim
  • Comanche, OK -- USA
Re: MAME SF3 cd loading
« Reply #1 on: September 18, 2008, 05:43:09 pm »
Do you have the CHD file? Not going to work without it.
Banacek
« Reply #2 on: September 18, 2008, 06:47:03 pm »
I have my CHD files in their directories under my rom directory. Do I need to specify a CHD directory in my mame.ini so it knows where to look? Thanks!
FrizzleFried
    • Idaho Garagecade
« Reply #3 on: September 18, 2008, 06:51:06 pm »
These titles originally had to load from CD and it took like 20 minutes.  Some of the ROMS do the same,  but show you a loading screen of sorts... I can't remember if it counts down but I seem to remember it does.  It only happens once then it's saved in NVRAM or something.   There are also ROM's that have a NOCD tag to them that doesn't do this.  Personally,  I let each load just to get it over with.
Banacek
« Reply #4 on: September 18, 2008, 07:11:31 pm »
I guess my confusion is whether or not it shows progress or just sits there, looking like it's frozen while it loads. I've been using the NOCD version for a while with great success, so I guess this is just curiosity more than anything. Is there a difference between the regular and NOCD version?
Ian
  • Last login:September 26, 2021, 01:50:35 am
« Reply #5 on: September 18, 2008, 08:45:05 pm »
my suggestion is leave it on over night.... you will find out in the morning if it froze or not.
Ginsu Victim
« Reply #6 on: September 18, 2008, 11:21:32 pm »
That's a bit extreme. Mine never freeze. If his are freezing up, he has an issue right there. It takes about 15-20 minutes, but the counter is supposed to always be running.
Banacek
« Reply #7 on: September 19, 2008, 01:35:04 am »
What does your directory structure look like? It seems like it's not finding the CHD file...
Banacek
« Reply #8 on: September 19, 2008, 02:47:46 am »
A word of warning: make sure that logging in MAME is turned off before you load a cd for a CPS3 game :) It's working now. Thanks for all the help!
