Author Topic: Printing Inkscape images - problems  (Read 2708 times)
Benevolance
« on: September 17, 2008, 06:47:10 pm »
I downloaded Inkscape. Fantastic program. Loved using it. I got my fancy control panel image all done up nice and fancy. I emailed a few photo places about printing...and none have ever heard of the .svg file format. I've sent the image off as a PDF file, but a PDF isn't a vector image anymore, is it? I had to shrink my 34" wide control panel down to 11" just to size it for export.
I know others on the boards have used Inkscape, but how have you handled getting your image printed?
zorg
Re: Printing Inkscape images - problems
« Reply #1 on: September 17, 2008, 06:58:15 pm »
if the source for making a pdf is vector then pdf is vector :D
pdf is some postscript language nonetheless vector definition of the stuff to print.
what I can't answer is the necessary shrinking ? I dunon why you have to do that. anyway send me your svg file and I save it as pdf, you can use the illustrator demo to do the ask.
I'm on the planning stage
TheShanMan
    • My Arcade (updated 1/30/13)
« Reply #2 on: September 17, 2008, 07:03:58 pm »
I was able to convert mine using inkscape, but I found that the resulting conversion wasn't identical to the svg. I found out that Scott at MameMarquees.com would have converted to raster anyway, so I did that myself so that I could be confident that the conversion was done correctly. If your printing service ultimately converts to raster, I would suggest doing the same. Find out what dpi they work with and convert it on your own. It'll be a slightly bigger file though. ;D
Benevolance
« Reply #3 on: September 17, 2008, 07:31:38 pm »
Zorg, when I saved the file as a PDF, it only saved the part of the image that was in the physical page boundaries for Inkscape. So I just shrunk the image down to fit the 8.5" x 11" landscape page and sent that off, so that the print shop could at least give me a quote.
Shanman, I was checking out Mamemarquees, too. What file format did you output to? Did you use Inkscape to do the conversion from vector to raster?
TheShanMan
« Reply #4 on: September 17, 2008, 11:06:40 pm »
I just exported to png using inkscape at 300dpi.
zorg
« Reply #5 on: September 18, 2008, 02:31:15 am »
here is the problem, go to the document // page setting and set the size to be the same than the whole size of the CPO.
then export as pdf, it should be OK
Benevolance
« Reply #6 on: September 18, 2008, 01:15:54 pm »
D'oh! I should have thought of that. Zorg, you are awesome. That solved the problem.
