Author Topic: Admin Buttons  (Read 2475 times)
Visitor Q
  • Last login:May 01, 2019, 09:09:30 am
  • The Saw Is Family
Admin Buttons
« on: September 17, 2008, 12:24:03 pm »
What admin buttons do you recommend for a control panel layout?
I was considering the following.
Pause
Esc
I was thinking one or two others maybe good for games like Future Pinball to select screen veiws or maybe just two in general to set whatever.
Ideas and thoughts please.
Thanks.
“Woe be unto him who opens one of the seven gateways to hell, because through that gateway evil will invade the world."
nipsmg
  • Last login:January 20, 2026, 10:46:56 am
  • ROONEY!! ERRGH!!
    • Arcadia
Re: Admin Buttons
« Reply #1 on: September 17, 2008, 01:00:08 pm »
Suggestions:
-Exit to frontend (your ESC may cover this)
-Enter/Continue/Select
-Menu (TAB for mame)
Visitor Q
  • The Saw Is Family
Re: Admin Buttons
« Reply #2 on: September 17, 2008, 01:10:23 pm »
Tab maybe a good one, I will have a keyboard draw so I will have access to a keyboard. I am more less looking for stuff that I will use a lot after configuration.
Re: Admin Buttons
« Reply #3 on: September 17, 2008, 01:12:26 pm »
I use 4 on all my CPs (but not necessarily ON the CP):
Pause
P1 Start
P2 Start
Exit to FE
TAG
  • Last login:May 23, 2014, 05:52:05 pm
Re: Admin Buttons
« Reply #4 on: September 17, 2008, 01:18:45 pm »
Pause
P1 Start
P2 Start
Exit to FE
I second those suggestions.
I may not have gone where I intended to go, but I think I have ended up where I needed to be.
-- Dirk Gently
Visitor Q
  • The Saw Is Family
Re: Admin Buttons
« Reply #5 on: September 17, 2008, 01:30:33 pm »
Yeah I mean I am going to have these for sure.
Pause
Esc.
Coin 1
Coin 2
Player 1 Start
Player 2 Start
I am more or less looking beyond those...
TAG
Re: Admin Buttons
« Reply #6 on: September 17, 2008, 01:44:21 pm »
Pause
Esc.
Coin 1
Coin 2
Player 1 Start
Player 2 Start
Personally (and that's really what's important when designing your CP, since you're going to be the one using it most), I wouldn't put anything other than those on the CP.  Like you said, you'll have a keyboard close by when you need to take care of administrative matters, so why clutter up the CP with them?
-- Dirk Gently
Todd H
  • Last login:August 26, 2024, 02:23:32 pm
  • It's Gameday!
Re: Admin Buttons
« Reply #7 on: September 17, 2008, 01:48:21 pm »
Pause
Esc.
Coin 1
Coin 2
Player 1 Start
Player 2 Start
Except for Pause, those are the one's I'm going with. Thought about pause but decided on coin op games it took away some of the authenticity.
mark shaker
  • Last login:March 04, 2022, 09:27:06 pm
  • Oh Crikey!
    • Mark's Basement Arcade
Re: Admin Buttons
« Reply #8 on: September 17, 2008, 01:56:37 pm »
On one cab, I have a separate little area for admin buttons so I went a little wild:
   Menu
   Select
   Escape
   Pause
   Test
   Reset
On some of the cabinet's panels, I don't have a joystick, so if someone doesn't stop me I'm going to add an "OK" button!!!
   - Mark
DaveStall
  • Last login:February 19, 2021, 05:56:25 am
Re: Admin Buttons
« Reply #9 on: September 17, 2008, 01:58:40 pm »
I only have Escape and Pause on my panel.  Other less used functions (Volume, Tab, etc.) can be assigned to shifted keys.  If you have young children, you will probably end up using the Escape key only in a shifted mode as well after about half a day.
Dave
Benevolance
Re: Admin Buttons
« Reply #10 on: September 17, 2008, 02:26:09 pm »
I liked Mountain's use of an admin bar, just above the control panel. It keeps the admin functions off the CP, but still gives you easy access to that functionality.
I think that my friends would abuse a 'reset' button, however.
Ginsu Victim
  • Comanche, OK -- USA
Re: Admin Buttons
« Reply #11 on: September 17, 2008, 02:32:38 pm »
My setup:
On panel: Pause only (both players, next to p1 / p2 start). Shifted function - Esc (p1 start + pause)
On top of cab: Tab (shifted with p1 start = F2 settings), in Mamewah it's shutdown.
Under panel (flip up front): Coin, Reset, Lightgun cursor
Soon to be added under panel: Save state, load state
Re: Admin Buttons
« Reply #12 on: September 17, 2008, 05:55:29 pm »
Enter is a MUST have if you are running PC games through your front end.  Some PC games have in game menus that require that you press the "enter" key to select/play the game, etc.  I created a button on my panel physically labeled "select" and configured it for the enter key.  Then I just assigned my frontend's "play game" key to be that button.  Kills two birds with one stone.
Ginsu Victim
Re: Admin Buttons
« Reply #13 on: September 17, 2008, 05:57:27 pm »
I have enter, arrow keys, and space as shifted functions.
Re: Admin Buttons
« Reply #14 on: September 17, 2008, 06:25:09 pm »
If you have a wife and/or kids I HIGHLY recommend a pause button - authentic or not.   :cheers:
Loafmeister
  • Last login:June 03, 2025, 01:49:49 am
Re: Admin Buttons
« Reply #15 on: September 17, 2008, 07:46:28 pm »
If you're getting old and frequent the can a lot, I also recommend the pause button :)
