Author Topic: Win98SE ACPI?  (Read 1656 times)
TheGameAh
  • Last login:June 09, 2004, 10:52:01 am
  • You are not FreakZilla.
    • Arcade Cab
Win98SE ACPI?
« on: June 12, 2003, 10:49:13 am »
I think that's the right term.  I might be wrong though.  Is Windows 98 SE smart shutdown compatible?  I know in Windows 2000 and Windows XP, if you hit the power button, the operating system will gracefully shutdown.  Does Windows 98 SE support this in some way, or do you have to shut it down through the menu?
BillyJack
  • Last login:August 17, 2025, 02:58:00 pm
  • Must...paint...cab...! Must...buy...marquee..!
Re:Win98SE ACPI?
« Reply #1 on: June 12, 2003, 11:14:13 am »
I'm pretty sure that Windows 98 SE has this functionality.  Check in the Control Panel under the Power management icon.  It probably has something similar to "when power button is pressed" then a drop down box that says "do nothing" "sleep" "shut down" etc.
just check under the different tabs (if there are any.)
BillyJack
Now I've had my head in an elephant, a hippo, and a giant sloth.
-Homer
nighthawk2099
  • Last login:June 10, 2015, 04:01:16 pm
  • I LIKE TATER-TOTS!
    • IRONMAME
Re:Win98SE ACPI?
« Reply #2 on: June 12, 2003, 12:10:20 pm »
Yes Win98SE does support the PowerDown/Shutdown thing.  We are running Win98SE on Dell Optiplex GX110 that do the power down.  No problems here.
bigmoe
  • Last login:July 16, 2004, 04:17:54 pm
  • I forgot my mantra!
Re:Win98SE ACPI?
« Reply #3 on: June 12, 2003, 04:34:16 pm »
I'm no expert, but doesn't this support also have to exist in the bios in order to work correctly?
What was that again?
Amra
  • Last login:July 27, 2024, 02:33:46 pm
  • Save a tree, Eat a beaver!
Re:Win98SE ACPI?
« Reply #4 on: June 12, 2003, 04:37:04 pm »
If you have an ATX Power power connector (you can tell because it is two rows of wires) on your MB, then you have have it in your BIOS.  If you only have an AT Connector (has only one row of wires) then you wont be able to use Auto Power Down, no matter what OS you use, instead you will get a screen that says "it is now safe to turn off your PC".
Save a Tree, Eat a Beaver!
_Iz-
  • Last login:March 17, 2026, 09:19:06 pm
  • Time to coin up!
Re:Win98SE ACPI?
« Reply #5 on: June 12, 2003, 06:52:39 pm »
This is not entirely accurate. I've seen computers with an ATX power supply that did not support ACPI shutdown. The computer would completely turn off when you click start -> shutdown but you couldn't press the power button to make it shutdown properly (and yes it was set right in control panel). ACPI support is largely determined by the bios but also requires an ATX powersupply. Both must be true for it to work. Some bioses are "supposed" to support ACPI but are buggy and the functionality was disabled for these in windows. (windows actually maintains an internal list of problematic bioses)
