Author Topic: Coin door wires help. Were to splice into before I start  (Read 1430 times)
ctozzi
  • Last login:November 24, 2022, 01:05:42 pm
« on: September 15, 2008, 12:32:55 pm »
So I want the authentic feel and the coin door needs to be lit up for that. Here are some pictures. The cable coming from the power supply in the connector in my fingers. My question is do i match up the yellow wires on both bulbs to the yellow on the connector, and the yellow w/white on both bulbs to the yellow w/white on the connector ? Then lastly how do I ground this whole thing ?
The last photo is the other end of the wire running from the power supply to the coin door(that I need to splice)
BTW it a Mortal Kombat 1 Dedicated cabinet
« Last Edit: September 15, 2008, 12:34:41 pm by ctozzi »
Current Cab's
Dedicated Killer Instinct 1
Mortal Kombat 1,2,3
Terminator 2
Rampage WT
WWF Wrestlemania
MAME MK1
Zelda Theme Bartop
ToplessZ
  • Last login:December 08, 2018, 09:55:34 pm
Re: Coin door wires help. Were to splice into before I start
« Reply #1 on: September 15, 2008, 12:37:09 pm »
Your getting the power from the isolation transformer, not the power supply.  Its 12v AC not DC. Connect yellow to yellow and y/w to y/w.  Then run a ground wire from that post on the isolation transformer block to the coin door itself.
ctozzi
« Reply #2 on: September 15, 2008, 12:41:21 pm »
post ? back to coin door attach how? sorry I'm a rookie with wires. Do you have a picture. I just dont wanna screw the game up
Current Cab's
Mortal Kombat 1,2,3
Terminator 2
Rampage WT
WWF Wrestlemania
MAME MK1
Zelda Theme Bartop
Neverending Project
    • Arcade Fixer
« Reply #3 on: September 15, 2008, 01:04:05 pm »
He is referring to the screw with the green ground wires on your transformer assembly. Run a wire from this screw to the metal of your coin door to ensure it is grounded to the rest of the cabinet ground. You just need to make sure the wire wraps around a screw, or similar ground "post" on the coin door.
ctozzi
« Reply #4 on: September 15, 2008, 01:05:43 pm »
awesome thanks, I want to do this right the 1st time so that's why i'm asking all the questions. Thanks again guys
Current Cab's
Mortal Kombat 1,2,3
Terminator 2
Rampage WT
WWF Wrestlemania
MAME MK1
Zelda Theme Bartop
  • Last login:October 28, 2025, 11:06:27 am
« Reply #5 on: September 15, 2008, 02:36:06 pm »
Also, I know it sounds trivial, but make sure you swap out the light bulbs with new ones.  There no sense in trying to get them to light if the bulbs are bad.  :)
~ D
