Author Topic: CP Wizard Editing trouble  (Read 1211 times)
shredso
  • Last login:January 27, 2020, 09:23:27 pm
« on: September 09, 2008, 09:44:04 pm »
I'm having a hard time with the editor.  I have a standard 7 button with tracball layout.  the only difference is I have a spinner directly above the trackball and 2 mouse buttons above that.  By default my top and bottom row of buttons are swapped.  I tried relabeling and just moving but I get these annoying blue lines pointing to where they were initially.  If anyone already has a layout made for this that would be awesome.  Should I just make one from scratch?
headkaze
  • 0x2b|~0x2b?
Re: CP Wizard Editing trouble
« Reply #1 on: September 10, 2008, 09:54:47 pm »
Those arrows are "Label Links" if you click on the button and select properties, then remove the Label Link and it will not draw an arrow anymore.
shredso
« Reply #2 on: September 11, 2008, 09:19:59 pm »
Thanks, i think I get it now.  The controls are linked to the label, not the button.  I was moving the buttons around rather than the labels.  Now to import a picture of my own control panel...
