November 14, 2025, 03:19:21 am
Any idea's?Already tried a heat gun.Not coming off good with it!
Slow going, isn't it?
Someone recommended magic erase for something. Might work here?
Do it like you do your metal control panels.FIRE!
Is that just straight black vinyl, or is it painted over? If it is just vinyl, you should not have had any problems with a heat gun. That stuff comes off super easy when warmed up.
Quote from: Ummon on September 11, 2008, 04:21:41 pmSomeone recommended magic erase for something. Might work here?Not unless you want to use 6500 of them. A Magic Eraser is a lot like wetsanding with 2000grit.
Magic Eraser is an extruded melamine. It resembles a white foam block. You use it wet. When you scrub the fibres act as an abrasive. It's quite effective, actually.
What he left out is that he was dry humping a Charlie's Angels.
Quote from: ChadTower on September 15, 2008, 02:46:28 pmWhat he left out is that he was dry humping a Charlie's Angels. There are much worse pins out there to dry hump...
By the way, I used the Orange Stripper Solvent.Worked like a charm!Thanx !
Did you have to dry hump the stripper or did you use a wetting agent?
QuoteDid you have to dry hump the stripper or did you use a wetting agent?I saw that one coming from a mile away!
shardian... I found this on your porch. Do you need to tell us something?
It was shivering in a box and had no batteries. Take care of your pins and other people won't have to.
Sheesh! Next thing you'll be telling me their is an organization that promotes equality and civil rights for illegitimate pinballs! What's this world coming to?
