Author Topic: Mala + X-Arcade - Scroll once, then stop  (Read 4241 times)
Necro
  • Last login:December 31, 2025, 03:36:17 pm
« on: September 09, 2008, 12:32:03 am »
Weird problem.  If I use my XArcade in Mala, I can only scroll one game per 'push' of a button.  It doesn't repeat the button press.  What's weirder is that the keyboard connected THROUGH the X-arcade works FINE.
Scrolling is still slow-ish with the keyboard, but it just stops dead with the controller.
Any suggestions would be appreciated.  I tried turning off scrolling acceleration and changing the keyboard polling, to no avail.
(Also, definitely not the controller, tested that first).
loadman
  • Moderator
    • MaLa
Re: Mala + X-Arcade - Scroll once, then stop
« Reply #1 on: September 09, 2008, 02:54:06 am »
It could be this:
Have a read
http://forum.arcadecontrols.com/index.php?topic=59399.msg585895#msg585895
It's possible that a feature may be introduced to MaLa in the future to combat it.
Necro
« Reply #2 on: September 09, 2008, 09:45:05 am »
Yup, that sounds like the issue.  It's weird that no other front end displayed this issue...
So...any ideas on when it would be added? ;)
