January 30, 2026, 11:12:31 am
Thanks Eric,I actually have both an Apache and a GGG up/down spinneroverall I like the feel of the Apache better, but it's a matter of space. the GGG spinner is a really nice too, but much smaller so it will fit very easily, I have to see how hard the apache will be to squeeze in therehey I got the trackball in, so we'll see
Very nice, i'm impressed with the laminate bending !! you should be proud of yourself.
Bender!! We need some complete pics of this thing! How about a quick vid of it folding up & down?
Are these for sale?
more shots of getting the trackball inI tried a bunch of different cabinet hinges but none of them worked, a piano hinge would work but you'd see it, so after much searching I found these "invisible" hinges at woodcraft and they'll work great!here we are the prototype coming togetherhere it is all folded upa couple things I found along the way, I really have to make it a little wider so there is a little more room for your hand to the left of the joystick.I think I'm going to make it an inch wider and slide the joystick over an additional 1/2"to the rightI'm using mostly 1/2" MDO for the construction because I want it to be as light as possible and I'm going to use black laminate to cover the whole thing and finish it off with 5/8" black T-molding ( 1/2"+ laminate on each side = 5/8")I'm still waiting on the computer, I think DHL has lost it! Dell sent it out on the 19th and I've been traking the shipment since then and it hasen't been updated in a week so I called DHL and they don't know where it is so If Dell has to make me a new one this could really set me back another monthI guess it's ok I still have to go from prototype to finish and configuring Mala and load all the games, emu's, software, videos, snaps, marquees, custom front end and whatnot which will take some time
