Author Topic: 'Sealing' slight water damage?  (Read 2892 times)
whines
  • Last login:June 10, 2024, 04:34:10 pm
« on: September 04, 2008, 03:16:52 pm »
I'm working on restoring an old cabinet that's gotten a little bit of rain on it. The bottom 6" were terrible and have been cut away, but the rest of the cabinet is fine except for a slight puffiness around the edges, barely enough to be noticable...the wood is slightly flaky in this area, but it's still stong.
Is there anything I can (or should) do to this area before sanding it flat? Or should I just not worry about it?
Re: 'Sealing' slight water damage?
« Reply #1 on: September 04, 2008, 03:18:06 pm »
If you feel it's strong enough to leave you can fill the edge with Bondo.  That should give you a good edge on which to attach a new base.
In fact there is a good tutorial on this here.
« Last Edit: September 04, 2008, 03:21:22 pm by ChadTower »
