Author Topic: Track and Field - High scores not saving on running events  (Read 6616 times)
TxGlenn
  • Last login:June 03, 2015, 03:34:13 pm
« on: September 02, 2008, 08:27:22 pm »
I found some posts on this topic but didn't find any definitive answer/solution.  I am running MAME v.125 and my Track and Field doesn't save times on the running events (100 meter dash, 110 hurdles).  It saves the other events just fine.  I tried deleting my nvram file which cleared out all the high scores, but still does not recognize any worlds records in the running events.  They are all "0.0" .
Anyone know a solution for this?
rlehm
  • Last login:September 30, 2010, 09:04:25 pm
Re: Track and Field - High scores not saving on running events
« Reply #1 on: September 02, 2008, 11:50:07 pm »
that sux. my friends come over specifically to try and beat my times at this game. that would suck.
scary
  • Last login:October 20, 2008, 08:07:29 pm
« Reply #2 on: September 03, 2008, 08:29:43 pm »
I'm having the same problem with hyper sports also, it's very annoying.
Tafoid
  • Last login:February 12, 2025, 04:47:22 am
  • Emulation Devotee
    • MAMELOAD TNG (Front-End)
« Reply #3 on: September 03, 2008, 09:39:48 pm »
There is a DIP switch which you need to toggle called "World Records".  Toggle to "Erase on Reset" and restart MAME.  Then, adjust this DIP back to "Don't Erase".  You should have default high scores/records for all events.  If the NVRAM is not created properly, you'll get this 0.00 behavior you mentioned.
Also, a few weeks back, I made a program which rewrites the NVRAM from these two games and sets the world to reasonable levels for the average gamer (the default qualifying scores on easy).  You can obtain that here:  http://mameload.mameworld.info/trackfldreset.zip
« Last Edit: September 03, 2008, 09:45:55 pm by Tafoid »
31spoonerstreet
  • Last login:July 01, 2015, 07:38:48 pm
« Reply #4 on: September 04, 2008, 01:49:38 am »
sorry can't help on the original problem but very nice utility to clear the scores. Thanks alot.  Couldn't get the records on javelin or 100M ever so now i have some realistic records to keep
scary
« Reply #5 on: September 04, 2008, 02:07:27 pm »
yay it worked.  Thanks alot
ps. very sexy program
« Last Edit: September 04, 2008, 02:17:48 pm by scary »
TxGlenn
« Reply #6 on: September 04, 2008, 08:02:42 pm »
Yes, thank you very much!
I had tried the DIP switch reset but that didn't solve the problem.  Your little app worked perfectly.
TxGlenn
« Reply #7 on: September 05, 2008, 08:12:34 am »
Tafoid -
Would this app cause my MAME key mappings to reset to default as well?
galaxian77
  • Last login:November 05, 2025, 03:03:26 am
  • Groovyarcade fan !
    • Arcade Sunday (YouTube)
« Reply #8 on: September 08, 2018, 04:22:48 pm »
Yes, the dip switch trick fixed this for me!
Check out my home Arcade YouTube channel: https://www.youtube.com/channel/UCLKl6BrSjDsvCHIL2Blql-A
Still loving the classics, 30+ years later! 5 dedicated MAME cabinets: GroovyArcade, some Arduinos, real CRTs, ATI VGA cards, and some crazy hacks... Love it.
