Author Topic: DK monitor bezel question  (Read 1596 times)
RetroACTIVE
  • Last login:January 28, 2024, 04:27:52 pm
  • Gramps
« on: September 02, 2008, 10:37:53 am »
I'm in the middle of a DK restore... my cab did not contain the black monitor bezel that resides on the inside of the cab.  I'm pretty sure its fairly uninspiring... basically thick black cardboard correct?
Does anyone have a pic of how the original is cut?
« Last Edit: September 02, 2008, 10:39:36 am by RetroACTIVE »
Happy Gaming!
Level42
Re: DK monitor bezel question
« Reply #1 on: September 02, 2008, 11:41:18 am »
This is not a EZ but the "Radar Scope Sanyo" which was in my cab....
Indeed, very simple but effective.
WunderCade
« Reply #2 on: September 02, 2008, 05:51:04 pm »
There are actually two pieces. There is a black flap that is stapled to the inside of the cab to the back of the marquee box area, that flap covers the top portion of the monitor space. Then the monitor itself has a black bezel around it (like Level42's pic) spanning the inside of the cab sided to side, and bottom to top, with that black flap over the upper portion. Both are constructed of thick black cardstock paper.
It's tough to explain. Hopefully that makes sense.
RetroACTIVE
  • Gramps
« Reply #3 on: September 02, 2008, 07:44:50 pm »
It makes perfect sense.  My cab had remnants of the second piece. I should be able to black out everything using a combination plastic bezel and black cardstock paper.
Thanks guys!
Happy Gaming!
