Author Topic: 2 Player bartop  (Read 2370 times)
Kronos
  • Last login:January 11, 2025, 02:00:32 pm
2 Player bartop
« on: August 31, 2008, 01:02:18 pm »
I will post some pics later today.. So far I have the sides and the back and bottom cut out. Dimensions are 18" tall by 24" wide to make room for  my big ass and someone elses.  19" lcd and a P4 2.6 ghz 1 gig of ram and 2 80 gig hdd.
after I took the pics I cut the brackets down to size and mounted them on the side panels. I also cut the back to the correct size.
« Last Edit: September 01, 2008, 10:09:50 am by Kronos »
Kronos
Re: 2 Player bartop
« Reply #1 on: September 01, 2008, 09:06:37 pm »
looks like it all going to fit.. might be pretty tight. I will post more pics tomorrow. I need to mount the top and make a control panel then it will be time to paint. : :dizzy:
Re: 2 Player bartop
« Reply #2 on: September 02, 2008, 09:16:05 am »
You putting a marquee on it? I built a 2 player bartop, you can see it in my profile.
It turned out bigger than I had expected, but I also agree that 24" is the minimal setup for 2 players.
Kronos
Re: 2 Player bartop
« Reply #3 on: September 02, 2008, 02:39:36 pm »
no marquee on this one. Going to put the monitor all the way up for a good viewing angle. I am putting this on hold until I figure out a way to attach the control panel and figure out how to cut a door in the back for maintenance
