Author Topic: DL2 framefile  (Read 8830 times)
FrizzleFried
    • Idaho Garagecade
DL2 framefile
« on: August 29, 2008, 01:56:36 pm »
I had Daphne running on my cab last year.  A hard drive crash later and I am trying to set it up again.  I only want to run DL, DL2 and SA.  I got DL and SA running no problem but I don't have a freakin' frame file for DL2.  I remember encountering this problem last year but for the life of me I can't remember how I resolved it...but I DO remember playing DL2 on my cab.
Any suggestions?
(PS: This is the OLD Daphne version)
MKChamp
  • Last login:December 24, 2025, 01:30:45 pm
  • Stil around.
Re: DL2 framefile
« Reply #1 on: August 29, 2008, 02:26:48 pm »
I've attached my frame file...is this what you need?
FrizzleFried
    • Idaho Garagecade
Re: DL2 framefile
« Reply #2 on: August 29, 2008, 03:12:02 pm »
I think that may be the framefile for the new version of Daphne?  It no work.
Sucks to get SA and DL up...but no DL2.  I remember distinctly being frustrated over the fact this happened before.
But I got it to work somehow.
MKChamp
  • Stil around.
Re: DL2 framefile
« Reply #3 on: August 29, 2008, 03:44:23 pm »
I havent updated my daphne is YEARS...so I know this isn't for the new version of Daphne. Maybe you can post your log file to give an idea of what is happening....
ahofle
    • Arcade Ambience Project
Re: DL2 framefile
« Reply #4 on: August 29, 2008, 04:56:22 pm »
I'll try to remember to dig mine up and post it here tonight.  I also have the old Daphne.
There is also a way to figure out the start offset by yourself by stepping through the video and marking certain known frames, although I can't remember how.
SGT
  • Last login:May 31, 2025, 10:10:32 pm
Re: DL2 framefile
« Reply #5 on: August 29, 2008, 05:44:40 pm »
Here's mine.  If its the right one, you'll probably still have to edit the first line to reflect the path to the files for your setup.  If the frame file is in the same folder as the files that are listed in the framefile, the first line will simply be a period.  Mine is set to what it is because I elected to put all my frame files in the same folder to make it easier for the front end to launch the many games that Daphne supports.
« Last Edit: August 29, 2008, 05:48:50 pm by SGT »
mrclean
  • Last login:August 10, 2022, 08:30:36 am
  • World Record Holder for Gun Smoke Dedicated & MAME
    • Guscade
Re: DL2 framefile
« Reply #6 on: August 29, 2008, 06:59:55 pm »
The one that SGT provided is the same one that i have.. i hope that they release an HD version of DL2 that's the only other one that i'd care to have on my machine in the better resolution. The HD Rips of DL, And SA look incredible
2,370,650 Gun.Smoke
Tim N.
  • Last login:December 06, 2016, 04:49:21 pm
    • RalphWiggum dot Net
Re: DL2 framefile
« Reply #7 on: August 30, 2008, 12:38:44 am »
What is the exact size of your .m2v file? I have 3 or 4 different versions of dl2 for daphne and the different framefiles I have are 0, -66, and -67 ...... Have you used the framefile wizard before?
ahofle
Re: DL2 framefile
« Reply #8 on: August 30, 2008, 01:54:04 am »
Here's mine (my dl2.m2v file is exactly 1,718,717,520 bytes):
\daphne\roms\dl2
-63 dl2.m2v
FrizzleFried
    • Idaho Garagecade
Re: DL2 framefile
« Reply #9 on: August 30, 2008, 02:17:09 am »
I just re-encoded the DVD and it created a framefile for me.  Thanks for the efforts folks...now to figure out how I used to launch Daphne within Mamewah....
Tim N.
Re: DL2 framefile
« Reply #10 on: August 30, 2008, 08:31:49 am »
This should get you started- plenty to change though...
### daphne.ini (mamewah v1.62) ###
emulator_title                            Daphne
### List Generation Settings ###
rom_path                                  c:\daphne\roms
rom_extension                             zip
dat_file
nms_file                                  c:\daphne\daphne.nms
catver_ini_file
list_generation_method                    rom_folder
### Execution Settings ###
pre_emulator_app_commandlines
emulator_commandline                      c:\daphne\daphne.exe [name] vldp -framefile "C:\daphne\framefile\[name].txt" -fullscreen
post_emulator_app_commandlines
general_app_commandlines                  c:\cpv2\cpv2.exe -p=[emuname];c:\cpv2\cpv2.exe -b="c:\cpv2\images\mamewah.jpg";c:\histview_consoles\histview.exe -r="[emuname]"
### Artwork Settings ###
artwork_image_paths                       C:\daphne\snaps
movie_preview_path
movie_artwork_no                          1
enable_fuzzy_search                       0
history_dat_file                          auto
history_dat_artwork_no                    2
### Screen-Saver Settings ###
enable_music_in_screensaver               0
select_random_game                        0
saver_type                                saver_commandline
movie_path
movie_fullscreen                          1
quit_delay                                30
saver_commandline
### Additional Settings ###
music_path
lcd_display_file_path
description_display                       [description]{scroll}
### Settings used by MAMEWAH ###
current_list                              0
FrizzleFried
    • Idaho Garagecade
Re: DL2 framefile
« Reply #11 on: August 30, 2008, 12:06:46 pm »
Thanks Tim...I am sure that will help a bit.
FrizzleFried
    • Idaho Garagecade
Re: DL2 framefile
« Reply #12 on: August 30, 2008, 03:53:54 pm »
I got everything up and running... 95% anyway.  The last thing I need to do is figure out how to change the names appearing in my list from the rom name (lair, lair2, ace) to full names.
...and ideas?
Tim N.
Re: DL2 framefile
« Reply #13 on: August 30, 2008, 04:56:42 pm »
...and ideas?
Yep...if you look in the config file I posted, there is a NMS file that does this exact thing... here is what my nms file looks like...
Astron Belt (Hitachi)|astron
Astron Belt (Pioneer)|astronp
Badlands|badlands
Bega's Battle|bega
Cliff Hanger|cliff
Cliff Hanger (Alt)|cliffalt
Cobra Command (Astron Belt Hardware)|cobraab
Cobra Command (M.A.C.H. 3 Hardware)|cobram3
Dragon's Lair (US Enhanced 1.1)|dle11
Dragon's Lair (US Enhanced 2.0)|dle20
Dragon's Lair (US Rev F2)|lair
Dragon's Lair 2: Timewarp|lair2
Esh's Aurunmilla|esh
Galaxy Ranger|galaxy
Goal To Go|gtg
Space Ace (US Enhanced 1)|sae
Space Ace (US Rev A3)|ace
Star Blazer|blazer
Super Don Quix-ote (Long)|sdq
Super Don Quix-ote (Short)|sdqshort
Thayer's Quest|tq
M.A.C.H. 3|mach3
Us Vs. Them|uvt
Just name the file daphne.nms and point to it in mamewah see my posted config..... You can actually name the stuff on the left anything you want as long as the right hand side has the correct file name..
The left is waht will display, the right is the rom name....
somunny
  • Is it hot in here?
Re: DL2 framefile
« Reply #14 on: August 30, 2008, 05:12:13 pm »
