Author Topic: K7000 series, Shutdown  (Read 1317 times)
ToplessZ
  • Last login:December 08, 2018, 09:55:34 pm
« on: August 26, 2008, 01:25:43 pm »
I have a K7000 that I was adjusting the setting on when I accidently let my hand touch the frame.  I got a little zap and then I lost the picture completely and smelled something burn.
I replaced IC4 and now it turns on for a brief second and then shutdown.
Anyone know what fried? :banghead:
« Last Edit: August 26, 2008, 02:07:41 pm by ToplessZ »
SirPeale
  • Green Mountain Man
  • Trade Count: (+23)
Re: K7000 series, Shutdown
« Reply #1 on: August 26, 2008, 01:29:18 pm »
You got zapped when you touched the frame?
Something isn't wired correctly.
ToplessZ
« Reply #2 on: August 26, 2008, 02:37:41 pm »
I replaced the HOT(Q11, I think is what it says), then turned it on and it didnt even try to turn on, but R103 started to smoke, and the large white cement resistor got really hot, so I immediately turned it off.
SirPeale
« Reply #3 on: August 26, 2008, 02:53:18 pm »
Is this wired to an isolation transformer?
ToplessZ
« Reply #4 on: August 26, 2008, 03:13:50 pm »
yea, its wired to an ISO. It worked fine until I touched the frame.
