Author Topic: Mala work with Vista 64??  (Read 4818 times)
bent98
  • Hyperspin Moderator
« on: August 25, 2008, 10:05:10 pm »
Anyone confirm or deny if it works with Vista 64?
loadman
    • MaLa
Re: Mala work with Vista 64??
« Reply #1 on: August 25, 2008, 10:16:54 pm »
Good Question.  I have no way of testing here.
My Question. Why would you be dedicating a high end PC that can run Vista 64 to a Cab?
retrometro
  • Last login:May 24, 2024, 09:11:44 pm
    • Arcade, mame, retro... and the gp2x.
« Reply #2 on: August 25, 2008, 11:46:05 pm »
I've tested MALA 1.04 and 1.05 on Vista x64 with and with SP1.
However, as of this writing, soft-15khz does not work with vista x64.  :-(
-------- gp2x and retro... play it forever! ------------------------
http://www.youtube.com/view_play_list?p=0EE573E86D5A86E0
bent98
« Reply #3 on: August 26, 2008, 06:57:49 am »
Humm Is salior working on a fix for soft 15?
I wonder if LED Blinky works with Mala as a plug in Vista 64?
Loadman reason why you want to run vista 64 is for bette preformance on the newer games emulated in Mame. There is a 30% increase with a optimized 64bit build.
Paul Olson
    • Paul's Arcade
« Reply #4 on: August 26, 2008, 05:42:39 pm »
MALA works on both XP64 and Vista 64. Make sure you delete the keyhook dll, it can cause problems in 64. Caused MAME to hang for me.
Loadman - I recently upgraded my desktop pc and my cab PC. The more powerful system went in the cab. There are games that I want to play on my cab that require a high end computer. I quit playing PC games years ago so my main comp doesn't need as much power. The price difference between a AMD system and a core2duo at 3Ghz is less than $100; now is a good time to put some horsepower in a cab.
loadman
    • MaLa
« Reply #5 on: August 26, 2008, 08:23:26 pm »
WoW   :o
A real change
When I first started findling with mame people would repurpose their old PC to play 80's video games on a cab..
I guess with the price of PC's dropped it can be affordable to have a 'kick ass' pc in a cab now.  :-)
ALSO
The next version of MaLa will automatically not load keyhook.dll unless it detects OS is Windows 98 or ME.  ;)
« Last Edit: August 26, 2008, 10:28:04 pm by loadman »
retrometro
« Reply #6 on: August 26, 2008, 09:22:33 pm »
yeah, my first mame pc was a pentium pro 200.  played classics just fine.
then got a pentium 3 in the cab.  that played a lot of newer 2d shooter/ fighting games fine
then a pentium 4.  that played pretty much the vast majority of the games including some 3d games
now with an oc'd core2duo, a lot of 3d games are playable except some of the higher bar games like gauntlet legends
bent98
« Reply #7 on: August 26, 2008, 10:09:27 pm »
retro do you know if LEDblinky works with vista 64?
retrometro
« Reply #8 on: August 27, 2008, 11:40:42 am »
sorry but i don't.
arzoo
  • Last login:January 26, 2025, 08:51:53 am
  • Robots WILL kill you.
    • LEDBlinky
« Reply #9 on: August 30, 2008, 08:27:12 am »
It should, but I have no way to test.
Robots will kill you.
Arcade Addiction
