Author Topic: How do you cut out shapes accurately?  (Read 2462 times)
  • Last login:Yesterday at 12:10:15 pm
« on: August 23, 2008, 07:50:32 pm »
I'm making a panel which is going to act as a bezel and a marquee retainer so I need to cut three holes and they have to be perfect (one is a semicircle and the other two are rectangles).  I have a plunge router and a 1/2" dado bit which I'm going to use to make most of the cuts.  I only have a 1/4" flute cutter thing but I can't use it because I'm putting a bevel on the edge when I'm done cutting and my chamfer bit has a 1/2" bearing - this is why I have to use the 1/2" dado cutter - I'll have to make about 3 passes to get all the way through...  Anyway, I tried doing this last night and it came out OK but there were two spots where I "overshot" my mark so I have to recut everything.  Is there a method to this or should I just be winging it like I do everything else?   :cheers:
scotthh
  • Last login:June 06, 2012, 10:03:42 pm
Re: How do you cut out shapes accurately?
« Reply #1 on: August 23, 2008, 09:01:37 pm »
Good luck... At least when I wing it I don't get too mad that nothing lines up right. When I measure it and it's wrong  :banghead:.
Btw, Between that thead and this (and beer), I feel less bad about f'ing up another 12' piece of crown molding...back to the Depot in again in the morning...
Oh, I don't have an answer for you question, but posting is part of my catharsis, hope you don't mind.
« Last Edit: August 23, 2008, 09:03:17 pm by scotthh »
Jdurg
« Reply #2 on: August 23, 2008, 10:08:02 pm »
For the rectangles, have you thought about creating a pattern out of straight boards and placing it underneath the item you're cutting?  You then use the plunge router and plunge a small hole in the middle of the part you're cutting out.  Then switch to a pattern cutting bit and just guide the router along the pattern on the bottom.
For the semi-circle, just cut out a full circle on a pattern board, then cut the circle in half and put a straight edge along one side and repeat again with the pattern cutting bit.
Donkey Kong High Scores:
1): 49,500
2): 35,600
3): 30,100
4): 29,400
5): 28,200
shmokes
  • Don't tread on me.
    • Jake Moses
« Reply #3 on: August 24, 2008, 12:51:39 am »
I make it over and over again in 1/4" hardboard (Masonite), sometimes starting in cardboard, with a jigsaw and sandpaper.  When I finally have one I'm happy with I transfer it to the wood with my router and a pattern bit.   ;D  Not efficient, but it makes up for my deficiencies.
Best Kid iPad Apps
Blanka
« Reply #4 on: August 24, 2008, 02:03:01 am »
Is wood (or woodlike stuff) good for a bezel Uberhaupt? It is mostly too thick, edges are not fine and finish is not nice. Why not use plastic or stickers on plexi/glass and have it water-cut or plotter-cut?
