Author Topic: XM-1801 N (Nintendo)  (Read 4782 times)
Boingo
  • Last login:March 14, 2014, 09:13:41 pm
« on: August 22, 2008, 03:38:57 pm »
I have a Nintendo Vs. Dualsystem Table MDS-TBL-US (red tent) with two minitors, one working, one not.  The non-working monitor squashes the entire display into a single vertical line.  The working monitor has some trouble with the white and other bright colours sparkling.  I am assuming this can be fixed with a caps kit.  I am uncertain how to fix the non-working monitor though.
The sources I have seen so far say that Nintendo used Sanyo EZ20 in its machines.  The frames of the monitors, and the manual I downloaded off the net for my machine, identify the monitor model as XM-1801 N.  Because the two monitors are mounted back to back, it will be extremely difficult to locate any other markings without extracting one of the monitors from the cabinet.
:dunno
Does anyone have any further information about this model of monitor?
Does anyone know where I may find a proper caps kit for this model of monitor?
<<EDIT:  I just ran across a post saying the XM-1801 N monitor was made by Sharp.  Can anyone confirm this?>>
« Last Edit: August 22, 2008, 03:45:40 pm by Boingo »
Ken Layton
  • Guru
  • Technician
Re: XM-1801 N (Nintendo)
« Reply #1 on: August 22, 2008, 04:05:30 pm »
See Peale's reply # 61 in the Monitor FAQ for pictures of vertical and horizontal deflection failures.
Yes the red tents used Sharp XM-1801 monitors because they have an 18 inch tube instead of 20 inch. Both of your monitors should get capkits installed and cleanup all the dust/dirt in there too.
Boingo
« Reply #2 on: August 22, 2008, 04:19:32 pm »
So my problem with the second monitor is a horizontal collapse.
Is there any more information?
Will a caps kit alleviate that problem, or is there something more to that?
Clean those things?  Eeeeeeeeeeeeeewww!
Ken Layton
  • Guru
  • Technician
« Reply #3 on: August 22, 2008, 10:44:56 pm »
Here's the service manual for the 2001 which is the same as an 1801 except for tube size:
http://arcarc.xmission.com/PDF_Monitors/Atari%20Monitor%20TM-304%201st%20Printing%20Sharp%2019in%20Color%20Raster.pdf
Zanen Electronics in Texas has the capkits you need. Kit # 302 is what you want. Only $7.95 per kit. Telephone: (806) 829-2780 and they accept credit cards. Free shipping on orders over $25.
Boingo
« Reply #4 on: August 22, 2008, 11:24:58 pm »
Oh boy!  :D  I feel like a kid in a candy shop!
I hope it wasn't too much trouble for you to find that.
 :notworthy:
Merçi, Danke, and Thanks.   ;D
