Author Topic: arkanoid resolution  (Read 2623 times)
deano728
  • Last login:November 04, 2013, 10:59:53 am
arkanoid resolution
« on: August 22, 2008, 12:28:03 am »
What screen resolution should arkanoid be set?  I have it at 356X288 which is supposedly the default, but the ball is super choppy.  Everything else looks good, though.  When trying different resolutions, I can get the ball smooth, but then part of the screen is cutoff.
Paul Olson
    • Paul's Arcade
Re: arkanoid resolution
« Reply #1 on: August 22, 2008, 04:44:50 am »
I checked MAWS. The actual resolution is 224 x 256, so if you are using a horizontal monitor try 321 x 256 or 352 x 256.
deano728
« Reply #2 on: August 22, 2008, 09:58:19 am »
Thanks, I'll give this a try.
Everything was working fine and then I went to play one day (it was set at 352X256) and the image for some reason was completely distorted.  So distorted that I couldn't even read the word arkanoid.  At other resolutions, I have issues with the ball being choppy or the image being cropped.  If I check "triple buffering" the ball flows smoothly, however the sound is choppy.
deano728
« Reply #3 on: August 22, 2008, 07:07:19 pm »
Thanks for the heads up on the resolution, it works GREAT!  Sorry for my ignorance, but where is MAWS so that I can check in the future and how did you come up with 321X256 from 224X256? Is there some formula for converting vertical screens to a horizontal screen.
scotthh
  • Last login:June 06, 2012, 10:03:42 pm
« Reply #4 on: August 22, 2008, 07:10:24 pm »
