Author Topic: Adding microswitches to U360's ?  (Read 5307 times)
M.Lanza
  • Last login:October 09, 2015, 09:51:03 am
« on: August 21, 2008, 03:39:39 pm »
I just got my U360's today and will be using them with the circular restrictor kit.
I was wondering if anyone has tried these sticks with microswitches installed to add clickiness to them.
The microswitches wouldn't be connected to anything and I guess the feel and action of the sticks would change,
but would they effect control functionallity in any way?
I just woke up, so my question may not be totally understandable.
Trample the weak, hurdle the dead
Ginsu Victim
  • Comanche, OK -- USA
Re: Adding microswitches to U360's ?
« Reply #1 on: August 21, 2008, 04:53:17 pm »
It's just the whole concept that doesn't compute.
One of the main things I love about my U360s is the LACK of clicks.
I grew up on leaf joysticks, so I'm not keen on microswitch joysticks.
fatfingers
  • Last login:April 17, 2025, 05:26:08 pm
  • Got UltraStiks?™
« Reply #2 on: August 21, 2008, 05:25:50 pm »
 :dizzy:
I guess I'm just too old.  *sigh*
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
W.W.P.M.D.?                                       I'm here to help ... I just don't do it. ™
Visitor Q
  • Last login:May 01, 2019, 09:09:30 am
  • The Saw Is Family
« Reply #3 on: August 21, 2008, 06:12:01 pm »
Do the 360 seem that unresponsive or sloppy?
“Woe be unto him who opens one of the seven gateways to hell, because through that gateway evil will invade the world."
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
« Reply #4 on: August 21, 2008, 06:15:34 pm »
That's definitely an original question ... I know that I'm too old, but adding clickiness ... wow!
 :dunno
Working: Not Enough
Projects: Too Many
Progress: None
Turnarcades
  • Craig @ Turnarcades
    • Turnarcades
« Reply #5 on: August 21, 2008, 06:28:50 pm »
Kind of defeats the point of using 360's doesn't it? An analogue stick shouldn't feel clicky as the space it passes through triggers optical sensors. You risk losing functionality by hacking in switches. If responsiveness is a problem, try using stiffer springs.
Franco B
« Reply #6 on: August 21, 2008, 06:40:22 pm »
Same here. If you want a U360 that clicks (without the 360 functions) buy a Sanwa JLW, (they are the same).
Ginsu Victim
« Reply #7 on: August 21, 2008, 06:45:04 pm »
Visitor Q:
Quit freaking out!
They're great sticks ;D
NickG
  • Last login:September 27, 2025, 08:06:19 am
  • Dig.
    • My Projects Page
« Reply #8 on: August 21, 2008, 08:57:02 pm »
I may add switches to mine later, but I am planning to actually wire them up, if I do.  IIRC, you would also need to add an actuator to the shaft which will strike the switches.  This would change the feeling, but only partially - the return-to-center action remains unchanged.  If you are really just adding them to attain a certain feeling, you may enjoy better results by attaching the U360's magnet and PCB to a joystick which already has that particular feeling.  This of course, limits the functionality of the controller similarly to using a restrictor plate.
Timstuff
  • Last login:April 16, 2014, 02:24:29 am
  • I feel asleep !!
« Reply #9 on: August 21, 2008, 09:04:40 pm »
err... got my U360s mixed up with my P360s... But still, this seems like a pretty pointless idea.
« Last Edit: August 21, 2008, 09:06:18 pm by Timstuff »
M.Lanza
« Reply #10 on: August 22, 2008, 08:06:24 am »
Huh, I guess that makes me the first.  :)
Anyway, I installed the microswitches along with the circular restrictor plate
and now it feels just like the jlw's that i'm used to.
The still have the full range of motion, so they don't seem to hamper functionallity at all.
I'll have to try it without the restrictor plate to see if that changes.
These sticks are very responsive, there's no problem with that.
The sticks I had before were sanwa JLW's which the U360's are based on.
When I mounted these sticks, it was kind of a shock to me how different they feel with the stock spring.
It's not that their sloppy, because they are well built, it's just that these sticks feels like they have no resistance.
While the stock sticks arn't right for me, they may be perfect for someone else.
Just about every aspect of these sticks is customizable. It's like a joystick that you can talior to your needs.
I was just wanting to try this out and see if anyone else has.
I will get some stiffer springs though.
Visitor Q
  • The Saw Is Family
« Reply #11 on: August 22, 2008, 08:29:32 am »
Visitor Q:
Quit freaking out!
I'm in overload mode with all this information!  :P
Blanka
« Reply #12 on: August 22, 2008, 08:49:24 am »
Optical? U360s work by utilizing the Hall effect. Even works through some cheese, hairballs or other puzz.
Ginsu Victim
« Reply #13 on: August 22, 2008, 09:42:18 am »
gimp_hand:
The stiffer springs will make a huge difference. I don't recommend anyone using the stock spring.
FrizzleFried
    • Idaho Garagecade
« Reply #14 on: August 22, 2008, 10:08:23 am »
Yup...a first.  I've heard of many people bitching about the clickiness but no one complaining about the LACK of clickiness of a stick....
...until now!   ;D
cadmium
  • Last login:January 03, 2021, 12:51:56 pm
« Reply #15 on: August 28, 2008, 06:26:23 pm »
I'm curious what kind of microswitches you used? I assume you just added them back where the original switches went? Would cherry switches fit?
Ummon
  • Trade Count: (+13)
« Reply #16 on: August 28, 2008, 09:10:45 pm »
...until now!   ;D
Kids. Actually, we have seen a few here and there say they preferred micro-switches because they grew up with SF, etc. I don't even remember a micro-switch stick in the 80s or early 90s, but I didn't play fighters. (I didn't often play video games after high school.)
Yo. Chocolate.
Stephen Hawking
M.Lanza
« Reply #17 on: August 29, 2008, 12:11:31 am »
I used the microswitches that came with my sanwa jlw's.
You can use any microswitch as long as they have the metal arms that protrude from them.
Ginsu Victim
« Reply #18 on: August 29, 2008, 08:28:20 am »
Not to sound rude, but this is ---smurf-poop---. I don't see the point in putting microswitches on such an expensive stick. Go with the JLWs instead.
Modding the U360 is a great ability, but not in this way.
« Last Edit: August 29, 2008, 09:13:13 am by GinsuVictim »
