Author Topic: Changing the Read-only attribute Folder in XP Pro  (Read 5275 times)
IG-88
« on: August 16, 2008, 01:42:48 pm »
I don't know why this is giving me such a headache but for some reason I cannot get my C:\mame folder to stay non-"Read Only". I can unclick the option as many times as I want but as soon as I close the folder and re-open it, it's right back to being checked as read only again. Anyone know how to fix this? :timebomb:
-HarumaN
ark_ader
  • I glow in the dark.
Re: Changing the Read-only attribute Folder in XP Pro
« Reply #1 on: August 16, 2008, 03:47:12 pm »
Is your folder shared?
Click on Start -->Run -->and in the box type CMD
You should have a dos box.
Type this in the subdirectory of your roms:  attrib -R <mame rom folder>
Don't type <mame rom folder> bit just the subdirectory name  - duh.... I know.  ;)
That should fix it, but I think it is a sharing issue or a program is using the rom directory so you should do this with no front ends or programs running, except the usual suspects like Norton......
Let us know if this fixed the problem.   :cheers:
gonzo90017
« Reply #2 on: August 16, 2008, 04:00:52 pm »
There's also a freeware utility that does the same thing.
IG-88
« Reply #3 on: August 16, 2008, 09:42:00 pm »
Thanks for the ideas guys but neither one did the trick.   :(
-HarumaN
SavannahLion
« Reply #4 on: August 17, 2008, 12:16:08 am »
Probably dumb questions, but it's best to ask to make sure.
Is it actually checked or is it grayed out?
On my system, the box is always grayed out (or browned or whatever the theme happens to be). It will even gray it out on brand new folders I create.
Do you have permissions to change that particular folder permissions?
The Windows permissions design drives me ape ---steaming pile of meadow muffin---. *NIX is so much better for handling permissions.
IG-88
« Reply #5 on: August 17, 2008, 10:44:32 am »
No dumb questions when it comes to this windows crap :P  I assume it's checked cause I can uncheck it and make my changes in mame.
See, the heart of my problem is that I want to change some of my default global options in mame32. Like game display graphics and whatnot. I can make the changes and play my games the way I want but as soon as I close mame down and later re-open it everything defaults back to the original settings. So I figured it was because the folder was set at read-only and not keeping the settings.
As for the permissions thing. I am the admin so I thought I could make any changes to the folders I wanted. Is there something else I should look at.
( & what is *NIX? )
-HarumaN
fatfingers
  • Last login:April 17, 2025, 05:26:08 pm
  • Got UltraStiks?™
« Reply #6 on: August 17, 2008, 02:53:40 pm »
As I understand it, that checkbox is only there to annoy people on XP.  It doesn't actually do anything.
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
W.W.P.M.D.?                                       I'm here to help ... I just don't do it. ™
Hoopz
  • Last login:Today at 09:59:38 am
  • Intellivision Rocks!
« Reply #7 on: August 17, 2008, 03:51:07 pm »
As is the ability to try and remove it.  I never had success with that.  Going to the root folder v. sub-folders, etc.  What a pain.
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #8 on: August 18, 2008, 02:33:12 pm »
( & what is *NIX? )
*NIX is short for "all the variants of unix, including aix, solaris, BSD, and linux".
I am repeating a prior question, but: Is it checked or "box filled in"?  Checked means there is a check mark in the box, "box filled in" means the box is filled with a grey/green/(depends on theme) square; you can go through the three states by clicking in the box if it starts filled in.  What about the files in the folder?  Have you checked the sub-folders?  (Specifically the ini folder, and the mame*.ini in that folder in your case)?  I wouldn't worry if the box is filled in and the files inside the folder aren't read only.
Robin
Knowledge is Power
IG-88
« Reply #9 on: August 18, 2008, 02:39:12 pm »
Filled in I guess. And as for all the sub folders and such everything else is non read only. Which makes this doubly frustrating as everything always defaults back to the original settings.   :dunno
-HarumaN
SavannahLion
« Reply #10 on: August 18, 2008, 04:44:30 pm »
Grayed out is expected behavior. Windows doesn't treat the "Read-Only" flag the same between folders and files. In other words, they don't necessarily mean the same thing. You can specify that all the files in that folder bet set to read only, but the folders will never* set.
This is why I prefer the way Unix handles permissions. It's a little more intuitive (or I understand them better I guess) right up until you toss in masks.
*Exceptions exist with judicious use of the attrib command and desktop.ini. Stay away from attrib, you don't need to use it.
ark_ader
« Reply #11 on: August 18, 2008, 06:50:49 pm »
With regard to my previous post, enter safe mode and try my suggestion again.
If anything is using or sharing that folder any attempts to change the folder attributes will not have an impact.
Also if it is XP make sure you don't have a security policy in place to prevent these changes.  Is the drive formatted NTFS or Fat32?
Oh and BTW the attrib command is your friend.  ;D
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #12 on: August 19, 2008, 02:33:39 pm »
Grayed out is expected behavior....
Yup, the problem is somewhere else; filled in box is fine.
Robin
Knowledge is Power
kudah440
  • Last login:September 18, 2019, 06:09:43 pm
  • The Aardvarks will rule the world!
« Reply #13 on: August 19, 2008, 02:36:49 pm »
Its true...it doesnt have anything to do with the checkbox or permissions, the Underwear Gnomes go in and RE-check it when you close the folder!  They will pay for their treachery.
All fear the Aarvarks.
"It puts the lotion on its skin, or else it gets the hose again..."
SavannahLion
« Reply #14 on: August 19, 2008, 11:23:00 pm »
When using a Windows PC on your daily work, leveraging attrib should not be a necessity.
Leveraging the attrib command is either a learning experiment or something has gone really wrong. For the purposes of the OPs problem, his solution lies elsewhere and not necessarily with folder permissions. A bad configuration perhaps that forces Mame32 to fall back to defaults. I have a vague tickling memory of running into a similar problem but the solution escapes me at the moment. Was it that one had to spool out the default configuration within MAME? Crap, it was so long ago.
BTW, ark_ader did you take a peek at the KB article I linked to? It explains all about the folder behavior with the Windows GUI in there.
« Last Edit: August 19, 2008, 11:25:39 pm by SavannahLion »
ark_ader
« Reply #15 on: August 20, 2008, 08:07:58 pm »
No but I will after I get some sleep.  NT folder permission documentation is sleepy stuff to read. When I passed my MSCE on NT4 all those years ago I was very much into the bones of the OS.  Now I need 5 candy bars to get the energy up.   :laugh2:
As I was about to sign off I had a thought.  If the drive was from another machine and it was formatted with NTFS, wouldn't the security on the drive have to be taken ownership  from the new NT?  Thus making the old NTFS drive read only?  IS that what happened IG-88?
Hmmm I think I'm babbling now.
I'm off.
  :laugh2:
headkaze
  • 0x2b|~0x2b?
« Reply #16 on: August 20, 2008, 10:12:56 pm »
I was thinking the same thing when I was reading this thread.
