Author Topic: Help - DMD Quits Working  (Read 5906 times)
JeepMonkey
  • Last login:July 13, 2012, 01:51:24 pm
« on: August 15, 2008, 08:35:47 pm »
The DMD on my JP - The Lost World has a problem.  After playing for around 10 minutes, the DMD goes from displaying great to displaying nothing.  Gameplay is just fine, only the DMD quits working.  No light at all.  A few months ago, this would happen, turn the machine off, wait a few minutes, then the DMD would patrially come on.  Now, it takes probably over an hour for the display to work again, but for only around 10 minutes.
Any ideas on how to fix this?  Do you fix DMDs or just replace them?
Pins:  Theatre Of Magic, JP The Lost World, Revenge From Mars
Re: Help - DMD Quits Working
« Reply #1 on: August 15, 2008, 08:40:15 pm »
DMDs can be fixed but it's all fine SMT soldering.  The problem may not actually be your DMD, though.  There are a lot of other reasons for a DMD to crap out and the fact that it craps out entirely, rather than partially crapping out, actually makes it more possible that the problem is something else.
Ken Layton
  • Guru
  • Technician
« Reply #2 on: August 17, 2008, 08:06:55 pm »
Yup, replace coonectors and rebuild the high voltage section of the power supply board.
JeepMonkey
« Reply #3 on: August 19, 2008, 08:55:00 am »
Thanks for the suggestions.  I will see what I can do.
« Reply #4 on: August 19, 2008, 12:39:50 pm »
No need to rebuild the high voltage section just yet.  Focus on the connectors.
I say do it anyway.  It can't do anything but make the DMD less likely to be trashed by an HV failure.
