Author Topic: NEC PG4 2940 what remote?  (Read 2227 times)
Twin-X
  • Last login:April 26, 2018, 05:59:44 pm
  • Yes this avatar was stolen too!!!
« on: August 05, 2008, 09:09:42 am »
Hi,
I just prurchased a nec 4pg 2940 multisync without a remote.
Now to adjust screen settings i need a remote to do this.
I thought the RD-331E was the correct remote so i bought one of these.
However it does not work. The remote is not broke as i measured output on my scope.
Can anyone tell me what the correct remote should be for this monitor?
Thanks,
Jeffry
Twin-X
Re: NEC PG4 2940 what remote?
« Reply #1 on: August 05, 2008, 09:15:19 am »
Hmm i have the correct remote.
It was a dipswitch on the back of the monitor that needed to be set.
Ummon
  • Trade Count: (+13)
« Reply #2 on: August 06, 2008, 06:22:53 pm »
Heheheh. Yep, I've been through that with an XM2950. I couldn't find any info on yours. What its scan range?
« Last Edit: August 06, 2008, 06:27:08 pm by Ummon »
Yo. Chocolate.
Stephen Hawking
Twin-X
« Reply #3 on: August 07, 2008, 05:50:37 am »
Indeed not much info to be found.
Model:       MULTISYNC 4PG 2940G
Max Resolution:       1024 x 768
Sync Type:       Unknown
H Freq/ V Freq:       15-50 Khz / 40-120 Hz
Tube Manufacturer:
Monitor Type:       Multisync/Multiscan
Tube Model:
Tube Size:       29
Connector:       BNC; 15 pin
The picture is excellent. Down side it weighs a ton !!!!
p.s.
Do you know how to see on what frequency the monitor is running? Or is there no on screen info?
« Last Edit: August 07, 2008, 06:09:23 am by Twin-X »
