Author Topic: LED Wiring  (Read 2673 times)
EnderWiggen22
  • Last login:March 23, 2010, 09:32:27 pm
LED Wiring
« on: August 04, 2008, 09:18:36 pm »
Hey. Just finishing up my cab, so I picked up 2 2.6 v 28mA red LEDs from Radioshack to use in the coindoor. I want to power them w/ my computers power supply. Does anyone know how to use the 5v or 12v lead to do this?
Terrorism and Patriotism are only separated by success
Franco B
Re: LED Wiring
« Reply #1 on: August 05, 2008, 06:48:50 am »
You can use either 5v or 12v.
Using the LED series/parallel array wizard at http://led.linear1.org/led.wiz gives the following results:
5v
12v
Neverending Project
    • Arcade Fixer
Re: LED Wiring
« Reply #2 on: August 05, 2008, 11:21:44 am »
That calculator is a great tool. If you use 12V and hook them up in series, however, if one LED goes out then neither will light. You can still hook them in parallel using 12V by using 180Ohm resistors instead of the 270 in the diagram, FYI.
EnderWiggen22
Re: LED Wiring
« Reply #3 on: August 05, 2008, 02:10:10 pm »
Wow, Franco. That was incredibly straightfoward and helpful. Thank you
EnderWiggen22
Re: LED Wiring
« Reply #4 on: August 05, 2008, 02:39:55 pm »
One more question: Can I do the parallel wiring like this?
         + A -                    Key:
          l     l
          l     Z                  A : LED
          l     l
         + A -                   Z : Resistor
          l     l
          l     Z                  O : Power
          l     l
         O    G                  G : Ground
Franco B
Re: LED Wiring
« Reply #5 on: August 05, 2008, 03:37:30 pm »
Your welcome. Im no expert by any means but I have found that site really useful.
Once again im no expert but I dont think you can wire it like that as there are two reistors inline with the top LED. (I may be wrong here)
Could you not wire it like:
         + A - - -                  Key:
          l          l
          l         Z                   A : LED
          l          l
         + A - Z -                   Z : Resistor
          l          l
          l          |                  O : Power
          l          l
         O         G                  G : Ground
EnderWiggen22
Re: LED Wiring
« Reply #6 on: August 05, 2008, 04:13:15 pm »
Gotcha. Good catch (makes sense now). I'm obviously no expert either... so I certainly appreciate the assist (saves me lots o' tinker-troubleshoot time)
