Author Topic: Lay arcade cabinet on its back for transport?  (Read 17718 times)
Jakobud
  • Last login:November 18, 2025, 02:28:46 am
« on: July 31, 2008, 04:28:49 pm »
My cousin just scored a Centipede for $100.  He's trying to figure out exactly how to transport it with his Jeep + Trailer.  You can lay an arcade game on its back to transport it, correct?  (Obviously padding the back,sides, etc and strapping it down securely)
Re: Lay arcade cabinet on its back for transport?
« Reply #1 on: July 31, 2008, 04:33:13 pm »
Yep.  I transported my Mortal Kombat about 230 miles this way.
shardian
  • Trade Count: (+23)
« Reply #2 on: July 31, 2008, 04:48:27 pm »
That is the way the majority of people transport them. You just double check everything is bolted in place first. Just lay down some cardboard, and use a tie down or two. No need to do anything special.
Mauzy
« Reply #3 on: July 31, 2008, 06:08:02 pm »
Ive transported all of my games that way. Also learned that a cocktail cab fits the back of a Cherokee without putting down the seats...
TOK
  • The Game Always Wins
« Reply #4 on: July 31, 2008, 09:14:33 pm »
Works fine. Just give it a once over to make sure nothing is loose before you lay it down, mainly the monitor. If the game has a monitor shelf, the monitor might not be secured.
Level42
« Reply #5 on: August 01, 2008, 01:31:44 am »
Most of  the uprights I transported were actually on their side (on a blanket of course to protect it) because that's the only way to fit them in my car. Indeed do check if everything is tight inside before any transport.
ArtsNFartsNCrafts
  • Last login:October 12, 2020, 09:22:50 pm
« Reply #6 on: August 02, 2008, 08:47:29 am »
I brought my DK home that way (although we only transported it about 30 miles).
Ummon
  • Trade Count: (+13)
« Reply #7 on: August 02, 2008, 05:07:31 pm »
Probably already over, but I'd suggest putting some padding underneath it. Doesn't matter if it's strapped down well - the vibration of metal, etc, against cab will be transmitted to the internals.
Yo. Chocolate.
Stephen Hawking
Kevin Mullins
    • Me on Myspace
« Reply #8 on: August 03, 2008, 10:33:54 am »
Honestly.... it doesn't matter how you transport an arcade machine, standing up, laying down, on it's back, on it's side, whatever and however you get it from point A to point B the same rules apply.
Check for loose parts and items before loading.
Pad to prevent dings , nicks and scratches.
Strap it down.
Check it all again when you set it up at it's destination before powering on.
When in doubt.... call in the professionals.  ;D
