Author Topic: SimpleTouch FE  (Read 184343 times)
cush
  • Last login:September 01, 2025, 11:46:08 am
Re: SimpleTouch FE
« Reply #160 on: May 03, 2015, 11:07:21 am »
Sorry to drag up an old post, I have been using this fine programme for a while and I love it.
I have an old megatouch cabinet that was non working so I decided to try putting in a pc running STFE and have just finally got it working on the original vga monitor in the merit cab.
Problem now is the homescreen shows all the games fine but when I select one the graphics go awol on me again.
I have used quickres and just about to try soft15khz but just wondered if I have missed something glaringly obvious in Simple Touch.
cush
Re: SimpleTouch FE
« Reply #161 on: May 06, 2015, 12:36:03 pm »
Ok im still having issue with trying to play anything on the old vga monitor in the megatouch cab.
The STFE menu pages all display as normal and show the screenshots as it should but as soon as a game is selected the screen goes all scrambled and nothing is playable.
I obviously need to set resolution for games but cannot see anywhere in simple touch to do this.
I know people have put newer hardware in these cabs and got everything working but I just cant find any info about how they cured this problem.
Any info or advice greatly welcomed, it's driving me mad lol
MTPPC
Re: SimpleTouch FE
« Reply #162 on: May 06, 2015, 12:54:51 pm »
Set the resolution lower from within the games you are trying to play. It would be nice to know the maximum resolution of the monitor you are using. What model is it?
http://pinballmd.com/
cush
Re: SimpleTouch FE
« Reply #163 on: May 06, 2015, 01:11:42 pm »
Hi, Monitor is a tatung type 58 if that helps
I can't see anywhere in STFE to set res in each game, these are the swp games not mame btw.
Lave Laar
  • Last login:January 04, 2022, 06:23:13 am
    • Freeware arcade related programs
Re: SimpleTouch FE
« Reply #164 on: May 06, 2015, 07:09:42 pm »
Does the games run ok when started manually? Without using the FE.
cush
Re: SimpleTouch FE
« Reply #165 on: May 07, 2015, 07:39:28 am »
Not tried that tbh, will give it a go later and see.
cush
Re: SimpleTouch FE
« Reply #166 on: May 08, 2015, 07:06:29 am »
Same issues with resolution when started manually.
soft15 will not work on win7 when I try it I just get a box up with all options - install ect all greyed out.
Quickres sorts my desktop ok and even STFE menu/game selection page displays fine yet all goes west when I try to play anything.
Maybe xp needs installing and try again.
TalkingHeadsFan
  • Last login:February 17, 2019, 03:29:46 pm
Re: SimpleTouch FE
« Reply #167 on: September 01, 2015, 07:58:20 pm »
How exactly can I set up SimpleTouchFE to launch a particular MAME ROM? I can't seem to find a straight tutorial.
Thanks,
-Doug
R083RT0
  • Last login:Today at 09:16:01 am
    • my videos
Re: SimpleTouch FE
« Reply #168 on: September 02, 2015, 07:12:42 am »
mine tm8k.ini looks like this....(in the folder config\config01)
[Game]
DisplayName=Touch Master 8000
Program=C:\MAME137\Mame.exe
Parameters=tm8k
Wait=1
Valerius
  • Last login:September 02, 2016, 03:38:22 am
Re: SimpleTouch FE
« Reply #169 on: January 08, 2016, 04:07:51 am »
Sorry to revive such an old thread...
Since the developer's website seems to be down, is there any way to get any skins for SimpleTouch FE?
So far I wasn't able to find any.
Valerius
Re: SimpleTouch FE
« Reply #170 on: January 15, 2016, 07:05:58 am »
To be more specific, I'm looking for the LCARS (Star Trek) skin for SimpleTouch FE.
I could try to reproduce it from the screenshot I was able to find.
But it would save me a lot of work if someone could provide me the thing...
nivenj
  • Last login:April 13, 2016, 08:13:43 pm
Re: SimpleTouch FE
« Reply #171 on: April 09, 2016, 06:03:55 pm »
Anyone ever modded a skin to have more than 16 snapshots? My config will allow upto 20 and I've allowed 17 in the skin, All the placeholders are there but the 17th image is always missing. If I remove the image from say the 7th slot, then the image in slot 17 will appear. It seems to just not want to display more than 16 images on a single page :-S
Lave Laar
Re: SimpleTouch FE
« Reply #172 on: May 10, 2016, 12:55:22 pm »
My ISP decided to stop the hosting of web-sites for all their customers.
Have not found a new place to put everything.
It's still available through the Wayback Machine  http://web.archive.org/web/20151030211650/http://home.online.no/~llindga/
So if you need any skins you can download them there.
bsellers100
  • Last login:June 19, 2018, 05:46:46 pm
Re: SimpleTouch FE
« Reply #173 on: December 12, 2016, 05:34:36 pm »
I have seen videos where this is used for emulators, yet can't find any directions on setting that up.  Any help in adding rom files and getting them to run?
richard_skinner
  • Last login:September 11, 2017, 04:53:31 pm
Re: SimpleTouch FE
« Reply #174 on: September 11, 2017, 03:44:10 pm »
sorry to drag up an old topic. first let me say I think the software is fantastic and has every feature I want. I understand how it works etc and understand the set up. it got it running ITBOX, jukebox etc.
one problem if anyone can help ( and I know its not supported anymore )
in all the config sets except the first one, it seems to load game 9 ( bottom right ) when I select game 3 ( top right ) when there are 9 games in a screen . tried lots of different skins, and changed the max number of images to 9 ( from 12) and tested it to death but it still does it
Tempted to completely un install or even try and get a copy of 1.14 to see if it does the same.
really frustrating as except for that its perfect. ive tried looking in all the read me files, tried 6 or 7 different skins and combinations of max number of images etc.
cheers for any help
cheers for any tips.
Drnick
  • Plodding Through Life
Re: SimpleTouch FE
« Reply #175 on: September 13, 2017, 01:11:13 pm »
Hi Richard, I spent ages and ages trying to solve a similar problem and never found an answer. I also tried every skin that I could and everything else worked fine but when I would click on certain games (Can't remember if was same tile as yours) a completely different one would load.  I'm sort of glad to see I wasn't the only one with the problem.  If you do get a solution post it here :)
Lave Laar
Re: SimpleTouch FE
« Reply #176 on: September 14, 2017, 09:00:43 am »
There was a similar problem to this once where a different game would load.
I thought it was fixed, but it could be I never checked for different configs.
I'm kinda busy with real life/work right now, but will take a look at it once I get some free time.
R083RT0
    • my videos
Re: SimpleTouch FE
« Reply #177 on: September 18, 2017, 09:39:26 am »
All games launch correctly with my simple skin (maybe because 16 games per page)
my simple skin:
adamgp
  • Last login:May 21, 2021, 10:48:32 am
Re: SimpleTouch FE
« Reply #178 on: July 18, 2019, 10:44:55 am »
Hi, did anyone ever find a solution to this problem?
I've found that the issue of the wrong game loading only occurs when you change from configuration to configuration and then load a game where its attract artwork is a video. I tried all video formats thinking it could be a SWF issue only, but it affects all video formats. GIF and other image formats load the correct game, but GIFs have a horrendous colour limitation.
Lave Laar - if you're listening, could you kindly open up the source code so we may fix this issue as it renders the software unusable with video formats?
Thank you
Lave Laar
Re: SimpleTouch FE
« Reply #179 on: July 22, 2019, 10:48:04 am »
Hi,
I'm not going to make the source code available, as it's in no state to be released.
However, I think I found the bug, and have made a new version 1.16.
I don't have a website anymore, but have uploaded it to one-drive.
Should be available here:  https://1drv.ms/u/s!Ag-miztRAHvMbFYSMjsgQemHZJM?e=ptIyfb
Let me know if this fixes the issue.
Drnick
Re: SimpleTouch FE
« Reply #180 on: July 22, 2019, 03:34:13 pm »
Hi,
I'll pull the old girl out of mothballs and have a play at the weekend.  :applaud: :applaud: :applaud:
adamgp
Re: SimpleTouch FE
« Reply #181 on: September 13, 2019, 04:32:14 pm »
Hi,
Hi Lave
Thanks for the response and sorry for the delay - I really didn't expect such a prompt reply and should have followed this topic.
Your fix has worked thank you! I've only tried SWFs file formats however. But thank you so much. What was the issue out of interest as I've asked so many people if they had the same problem and few seem to encounter it like myself? Is it related to the shutdown sequence only sometimes invoking after switching configs?
If you don't mind me asking are you open to further minor fixes/tweaks? Is so please see attached - when loading SWF attracts a large black border renders around the animation, this doesn't affect other video formats - but other formats on mass cause a CPU issue. Is it possible to reduce/remove this border? The green ticks show correct image attracts and the red arrows identify the video attracts with the border issue.
The only other very helpful thing would be a txt log of each game loaded with a timestamp - I could then analyse this on boot with a bat file to derive a "Players choice" config ini list that self adjusts!
Thanks again, Adam
macca_andy
  • Last login:January 16, 2020, 10:59:21 am
Re: SimpleTouch FE
« Reply #182 on: January 16, 2020, 06:34:35 am »
Hi, Is anyone able to help me get some old SWP games to run? I have downloaded a load of them but the error message i'm getting is sockets failed. I think maybe i need to run an emulator or something to get it to work?
Drnick
Re: SimpleTouch FE
« Reply #183 on: January 21, 2020, 04:14:46 pm »
You need to emulate a credit board to make things work. Can't point you in the right direction to the files directly here though.  Also another thing is make sure you have ffdshow installed as most games require it. Make sure to test outside of Simpletouch before attempting to add them.
Aladdin Wii Genius
  • Last login:April 20, 2020, 03:57:28 am
Re: SimpleTouch FE
« Reply #184 on: April 20, 2020, 03:46:34 am »
Hi there. Nice to see so many people using my configs for simpletouch FE. If you need any help on setting up my AIOFE feel free to join touchscreen machines on Facebook and I can helo, answer ALL your questions.
As they say you don't talk to the monkey, you talk the organ grinder. Cheers the one and only Aladdin.
Lave Laar
Re: SimpleTouch FE
« Reply #185 on: November 03, 2020, 05:26:55 pm »
I've had some time to fix some of the problems, and have released a new version.
* Fixed a bug that could cause an "Access vialoation" error when selecting certain configs with a large number of configs.
* Fixed a bug that could prevent a program from beeing launched if no picture was assigned.
* Removed the border around flash videos.
* Updated the function used on "Run on poweroff".  The old one didn't work on windows 7 and up.
* Added an optional attract mode.
* Added an option to log the launching of games.
Still don't have a webpage, but I put it on OneDrive.
Should be available here:  https://1drv.ms/u/s!Ais-EaM-BiA3b2fLbFTZ_ztxYag
betty02
  • Last login:January 09, 2021, 11:42:52 am
Re: SimpleTouch FE
« Reply #186 on: January 09, 2021, 04:54:49 am »
This is perfect thanks, I don't suppose you are able to host the actual emulators are you? All the popular sites have dead links etc. I need well I think I need inbox, inbox save and inde? Just creating a pub quiz machine as a lockdown 3.0 project but can't for the life of me figure out where to get these emulators!
Happy to be DM'd! Life saver :)
Easybeatuk
  • Last login:January 10, 2026, 06:48:32 pm
Re: SimpleTouch FE
« Reply #187 on: January 11, 2021, 08:10:47 pm »
Hopefully Lave Laar is still around.
With the end of Flash player using SWF files is no longer possible as flash player is uninstalled from Windows 10 via an update and apparently can't be re-installed. Is there a work around to this as AVI files are a lot slower loading.
hellraizer
  • Last login:March 24, 2021, 07:06:43 am
Re: SimpleTouch FE
« Reply #188 on: March 24, 2021, 07:03:55 am »
Hello all,
Hoping to find some help as i am really struggling setting up the simpletouch fe program. I am running windows 10 on a touchscreen pc, when i try to run the program it comes up with class not registered and then unable to do anything with the config set.
Thank you in advance
Easybeatuk
Re: SimpleTouch FE
« Reply #189 on: March 24, 2021, 05:34:54 pm »
It's a problem with Adobe/Microsoft removing Flash player from Windows, I dropped down to STFE version 1.12 and it worked again however that still did not fix the problem with flash/swf files.
I then lucked out, I followed a guide on swfmax.com to give their player the ability to play flash files and installed a version of adobe flash player that not only worked with swf player but Simpletouch as well.
I can't link but the version you are looking for is flashplayer32_0r0_371_winax.
Hope this helps
adamgp
Re: SimpleTouch FE
« Reply #190 on: May 21, 2021, 10:48:32 am »
Just noticed this, thanks for updating!
Lave Laar
Re: SimpleTouch FE
« Reply #191 on: September 01, 2021, 05:19:30 pm »
New version 1.18 released.
New in this version:
* Fixed a bug that would cause "Access violation" when using a launch image together with swf-files.
* Fixed a bug that would not clear the image/movie in the config program when right-clicking the image/movie.
* Fixed a bug in the auto-insert code that would add the program path to the image-setting.  Even if no picture was found.
* Fixed a bug when using a multi-config-ini skin that would not properly load the correct config-skin.
* Fixed a bug where drag and drop would not add programs to the currently selected config.
* Fixed a bug where quotes or double quotes could be deleted if they where at the start and end of the parameters box.
* Added an option to set screen resolution before launching a game and then reset to old resolution upon exit.
* Added an option to use a default launch image with the skin.
* Added an option to use a custom cursor with the skin.
* Added an option to exit back to FE from attract mode after x number of movie/picture changes.
* Added an option to automatically start the FE on Windows startup.
* Added an option to change drive letter inside all ini-files.
* Added code to support all direct show codecs for video-display.
* Added keyboard shortcuts for copying/pasting size/position properties in skin mode. See readme.txt for details.
* Updated to the latest version of bass.dll as there were problems with the reading of some tags.
* Changed the layout of the FeConfig program slightly.
* Changed the launch code to hide the window when starting a console game e.g. Mame.
Also created a simple new web-page.
Available at https://lavelaar.com/stfe
TheElectricMonk
  • Last login:September 25, 2024, 02:13:07 pm
Re: SimpleTouch FE
« Reply #192 on: September 19, 2021, 06:00:20 pm »
Thank you for this amazing piece of software! I tried it for the first time today and it does pretty much everything I need it to do.
Two questions:
1. Is it possible for a "normal user" (i.e. without having to bother you about tinkering with the code) to limit the options of the Poweroff menu?
I don't need Quit, Reboot, Standby or Hibernate, just Shutdown. Can I set these options somewhere?
2. Is it possible to exit the Poweroff menu? I haven't found a way yet, and it's a bit of a pain not to be able to go back to the main menu in case someone unwittingly touches the Poweroff menu button.
At the moment, my workaround is as follows:
Skin menu:
- "Hide poweroff image" unchecked
Poweroff menu:
- "Disable poweroff image" unchecked
- "Enable poweroff screen" unchecked
- "Use poweroff delay" 5 seconds
- Run on poweroff: c:\windows\system32\shutdown.exe, Parameters /f /s /t 0
This will ensure the machine shuts down ONLY if I keep the shutdown menu button pressed for really long.
Also, I set the Poweroff keys to something different than my "quit game" key, so any of the Poweroff functions won't get triggered accidentally.
As I said, this works nicely for the time being, just wondering if I had maybe overlooked another way.
Again, thank you!
Lave Laar
Re: SimpleTouch FE
« Reply #193 on: September 23, 2021, 05:17:30 am »
I have not put much effort into the poweroff menu, so there are not many options.
But agree that the option to exit the menu should be available.
You could rename/delete the images you don't need in the "ShutdownImages" folder of the skin.
However that would only hide the options and you would still be able to click the placeholders.
Another option is to activate the pin-code option.  This will make the shutdown menu unavailable if you don't know the pin.
And it will revert to STFE if you enter the wrong pin.
I will see if I can address these in a future version.
TheElectricMonk
Re: SimpleTouch FE
« Reply #194 on: September 24, 2021, 12:13:27 am »
Thanks for the reply!
I was just interested, since I've mainly been using MaLa as a frontend in my other non-touch cabs, and I guess I've gotten used to being able to opt out of the exit menu  :)
Now that I've had time to tinker with STFE a bit, I actually found that the delayed exit button strategy is my favorite option, since there is no way you can exit by accident. So no need to change anything on my behalf, and thank you again for your great work!
mviars
  • Last login:January 11, 2022, 02:25:30 pm
Re: SimpleTouch FE
« Reply #195 on: January 09, 2022, 08:39:05 pm »
IS there anyway to get around the "class not registered" pop up error when i start Simpletouch FE?
trick72
  • Last login:August 29, 2025, 04:00:45 am
Re: SimpleTouch FE
« Reply #196 on: May 22, 2025, 10:16:28 am »
Hi,
Is this frontend still available? I wanted to download the 1.18 but the website asks to "login"...?
hywelll
  • Last login:December 04, 2025, 07:37:03 pm
Re: SimpleTouch FE
« Reply #197 on: October 21, 2025, 02:58:44 pm »
Is there any way to do this in 2025? All the links are broken at every step i try :/ thanks
