Author Topic: Monitor tube exchange question  (Read 1473 times)
Tadao
  • Last login:January 17, 2025, 11:55:50 am
« on: July 23, 2008, 04:14:16 pm »
Hi
I have a 13" monitor chassis with its tube working perfect together. I recently got my hands on a 19" tube that has the same ohms on the yoke's vertical winding and the same number of pins on the connector for the neck board than the 13" tube.
I want to test if this 19" tube is working or not, by connecting it to the 13" monitor chassis and see what happens.
Is there a chance I can ruin my monitor chassis by exchanging the tubes? The only difference between both tubes is the inches... same pins, same ohms...
Regards
grantspain
Re: Monitor tube exchange question
« Reply #1 on: July 23, 2008, 04:29:44 pm »
the flyback transformer will output higher ht for the 19" than the 13",it will probably work but you will shorten the life of the flyback and a few other components
you may also find the picture smaller
Tadao
« Reply #2 on: July 27, 2008, 11:17:37 pm »
And Works!
The tube is taken from Panasonic 21" tv set.  The image is perfect.   ;D
Regards
« Last Edit: July 27, 2008, 11:19:11 pm by Tadao »
grantspain
« Reply #3 on: July 28, 2008, 06:33:46 am »
well looks good,just keep your fingers crossed the flyback will keep running
