Author Topic: How are you guys using programs like nestopia that aren't full screen?  (Read 4913 times)
vetteguy112233
  • Last login:April 28, 2012, 12:15:24 am
I've tried nestopia and a few other emulators for different systems that don't load full screen. I know you can tell nestopia to load full screen once opened, but it doesn't save that setting, so every time you use it, you have to make it full screen.
How are you guys getting around this issue?
SGT
  • Last login:May 31, 2025, 10:10:32 pm
I haven't run into an emu you couldn't put into fullscreen.  For nestopia, you should have a file called nestopia.cfg with the following line:
Code: [Select]
-preferences start in fullscreen : yes
RoomTenONine
  • Last login:August 20, 2008, 07:00:38 pm
Yeah, most emulators have command line options to tell the app to start fullscreen.
