Author Topic: AVG and MALA  (Read 1940 times)
protokatie
AVG and MALA
« on: July 17, 2008, 05:41:19 am »
Apparently, if anyone here has upgraded, AVG 8 (the free virus protection program) calls Mala (or more specificly, malakeyhook.dll) a spyware virus. Did I get a bad distro of Mala? Or is AVG at fault here?
As far as my new scan is for sure, ONLY malakeyhook.dll is the ONLY virus on my PC. (BTW, AVG calls it a potentially harmful program (class: logger)) Maybe this is because the DLL looks at the keyboard buffer directly? IDK, anyone have any insights? Just seems odd that AVG would have added a mala dll to their list of virii, unless it is simply looking for anything that hooks directly into the keyboard buffer (at the DLL level? What is AVG doing then? Decompiling the code???)
youki
  • Last login:October 12, 2025, 12:33:39 pm
  • Atomic Front End Creator
    • Atomic Front End
Re: AVG and MALA
« Reply #1 on: July 17, 2008, 07:09:21 am »
MalaHook is not a virus.  don't worry.
loadman
  • Last login:January 29, 2026, 07:18:10 pm
    • MaLa
Re: AVG and MALA
« Reply #2 on: July 17, 2008, 07:20:38 am »
Youki is correct.  ;D
I think you only need it for win 98/ME anyway,
Just delete that dll if you want and mala will work fine
There is a note about this on the right page of the website download page
http://malafe.net/index.php?page=download
Ummon
  • Trade Count: (+13)
Re: AVG and MALA
« Reply #3 on: July 17, 2008, 04:59:45 pm »
Yeah, AVG took it right out of the directory and I haven't missed it. But if you're worried, you can set 'exemptions'.
Yo. Chocolate.
Stephen Hawking
u_rebelscum
  • You rebel scum
    • Mame:Analog+
Re: AVG and MALA
« Reply #4 on: July 18, 2008, 12:27:49 pm »
You pretty much got it.  Most antivirus check the binary and look for commands that match "suspicious" commands.  Only thing not quite right is that no decompiling is needed to look for commands in dlls; the "suspicious commands" are calls to the OS API that can be used to do suspicious stuff, and the API calls look the same in all dlls.
Robin
Knowledge is Power
headkaze
  • 0x2b|~0x2b?
Re: AVG and MALA
« Reply #5 on: July 18, 2008, 01:31:27 pm »
Yep it's detecting the "virus" using heuristics rather than actual signatures from viruses. Since a keyhook would use API that would be common in keylogger apps I would suspect that is why it's being detected as a virus.
