Author Topic: arcade vga 1 resolution  (Read 1802 times)
G1zm0
  • Last login:October 05, 2020, 06:57:58 am
  • cute by day, devil by night
« on: July 16, 2008, 05:10:49 pm »
ive set up my arcadevga 1 card and installed the drivers and control panel.
i also installed quickres but the only low res i have is available is 640x480.
im using xp and a tv.
what am i doing wrong  why am i not getting lowes reses?
i am using the monitor in the vertical position as its for vert games only, also tryed to use the tools in avga to switch the screen to vert mode but wont let me says something about the wrong res to do it
ahofle
    • Arcade Ambience Project
Re: arcade vga 1 resolution
« Reply #1 on: July 16, 2008, 05:43:11 pm »
You're using an AVGA with a TV?  Maybe that has something to do with it.
G1zm0
« Reply #2 on: July 16, 2008, 06:07:22 pm »
other folk have used this setup, so it does work, well they says it does.some games look ok like twin cobra and raiden fighters 2, its just windows desktop is flickering and some games.
what res is avga ment to put windows into?
btw the tv is a uk scart one using a rgb  mame scart
deadsoulz
  • Last login:December 19, 2023, 02:24:28 pm
« Reply #3 on: July 17, 2008, 11:27:44 am »
Standard Resolution CRT TV's can only do 640x480 or 800x600 interlaced(can look crappy)  The ATI drivers are detecting you are using a t.v. and working appropriately.   ArcadeVGA was intended to use with real arcade monitors.  And could give you a sleuth of low resolutions for arcade games.  I have one with a Tri-Sync Wells Gardner that works well, other than I have a hard time finding a perfect resolution for a lot of arcade games.  Robotron was really tricky, and all my fighting games cps1/cps2/cps3, wanted to display in widescreen (bars on top and bottom).
G1zm0
« Reply #4 on: July 17, 2008, 11:50:02 am »
ahh ok so i am stuck with that res till i get another monitor. its only vertical games i will be playing on the tv.
and i will be playing all horizontal games on polo 2 (different machine)
wonder how pacman will look once i try it on tv
ahofle
« Reply #5 on: July 17, 2008, 01:09:19 pm »
OK sorry, I thought you were using composite or S-Video as a connection.  You should be fine using that TV with SCART.  Have you considered rotating the TV 90 degrees since you are planning on only using vertical games?  Which drivers did you install?  Hopefully the older AVGA ones, and not the AVGA2 ones.  You  may want to contact Andy at ultimarc about the missing low resolutions.
Not true.  He's using a European TV which has the same RGB capability as an arcade monitor via the SCART port.  Crappy USA TVs do not have that useful port, even though the tube inside is perfectly capable of pure arcade resolutions.
Ummon
  • Trade Count: (+13)
« Reply #6 on: July 17, 2008, 04:52:34 pm »
G: look up the SCART thread for help.
Yo. Chocolate.
Stephen Hawking
G1zm0
« Reply #7 on: July 18, 2008, 05:11:05 am »
i did look it up, its just to do with scart cables not avga so pointless
