Author Topic: Gameroom TV interference (help)  (Read 2676 times)
BUCKETHEAD
  • Last login:April 04, 2024, 07:31:52 pm
  • Don't hate the player .... Hate the Game
« on: July 16, 2008, 04:57:47 pm »
I have this small 13" TV on a shelf in the gameroom.
Usually have something arcade related running on it. (DVD'S)
It had no A/V or S VIDEO inputs.
So im using a RF Modulator to hook the dvd player to it.
Problem im having is interference,
in the way of faint lines all over the picture.
When i touch the RF box or the connections on the back of it.
Picture is crystal clear!
When i take my hand off, Bam! Lines are back!
How can i correct this?
Thanks so much!
ark_ader
  • I glow in the dark.
Re: Gameroom TV interference (help)
« Reply #1 on: July 22, 2008, 06:23:59 pm »
Have you tried a tin foil hat?
BUCKETHEAD
« Reply #2 on: July 22, 2008, 08:59:55 pm »
I wrapped some tin foil on the connectors.
But not a hat?
What is this method??
Kevin Mullins
    • Me on Myspace
« Reply #3 on: July 23, 2008, 10:13:11 am »
Sounds like a ground looping issue through some of the equipment.
Does any of the equipment you are using have a three prong plug?
(tv, rf modulator, video player, etc)
Some lengthy reading, but informative: http://www.epanorama.net/documents/groundloop/
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #4 on: July 23, 2008, 11:43:30 am »
This may not be what you want as a solution, but do you have a VCR in your set up? Run the signal through the VCR coaxial IN, and use the coaxial OUT to the tv. (This means ditching the RF box).
NO MORE!!
BUCKETHEAD
« Reply #5 on: July 24, 2008, 09:41:01 pm »
Yes!
I think i will just go to the thrift store,
And buy a cheap VCR!
Thanks for the advice.   :)
spanks_4
  • Last login:September 28, 2018, 10:41:24 am
« Reply #6 on: July 26, 2008, 05:16:07 am »
You can also run it threw a DVD player instead of going ancient egypt with the electronics equipment.
BTW: Wal-mart sells VCR's pretty cheap these days and that is brand new.
richms
  • Last login:January 07, 2025, 06:42:57 pm
  • s92a sucks
    • richms.com
« Reply #7 on: July 26, 2008, 09:25:48 am »
Easy solution is to replace the tv, small ones seem to go on the free lists all the time so join your local freecycle and see what turns up.
Otherwise I would be suspect of the quality of the modulator, there are some amazingly crap ones out there. A VCR tends to have a better one in it, and if you get a dvd/vcr combo then that solves the multiple boxes problem.
