Author Topic: Demul  (Read 10145 times)
DJ Infinity
  • Last login:January 19, 2012, 03:48:16 pm
Demul
« on: July 16, 2008, 04:36:27 pm »
Being a proud owner of NAOMI systems. I have been really interested in getting this to work to see the progress of the emulation of the NAOMI  system. Problem is I can't get past the unable to load error. HAs any1 on this forum got this to run and if so how? I'd like to know how to set this up to check things out.  :cheers:
If You Are Going To Meddle At Least Listen
clok
  • Last login:April 03, 2018, 10:58:39 pm
  • I can play PacMan till the screen splits!
Re: Demul
« Reply #1 on: July 18, 2008, 11:58:28 am »
I'm a bit out of touch on emulation for that system but last i heard in late Jan/early Feb they had the Bios running in the DC emulator, but since then I havent heard much at all, in fact i dont recall anything since then. maybe somebody else knows more then me ( that seems to be the case about most everything else knowledge based).
Clok
DJ Infinity
Re: Demul
« Reply #2 on: July 18, 2008, 03:30:44 pm »
It hasn't surfaced in NullDC yet. I guess no one on this forum uses and/or knows about demul. I can just content myself playing the real thing until Mame or NullDC getsit together. I am trying to save some money to ship my Marvel Vs Capcom 2 cart to Guru to dump so the emulation  community could have that to run.  :cheers:
DJ Infinity
Re: Demul
« Reply #3 on: August 01, 2008, 08:36:19 pm »
Nevermind. I finally got it to run on my own thanx for all the help  ::) it crashes on toyfighter right after the title screen
Jdurg
Re: Demul
« Reply #4 on: August 17, 2008, 12:01:13 pm »
How did you get it to run?  I can't load anything as it keeps saying "Unable to open "  ".  :(
Donkey Kong High Scores:
1): 49,500
2): 35,600
3): 30,100
4): 29,400
5): 28,200
DJ Infinity
Re: Demul
« Reply #5 on: August 17, 2008, 08:40:21 pm »
I Sent you a message on another forum. If you haven't got it running let me know  :cheers:
mighty1
  • Last login:October 16, 2008, 12:49:11 am
Re: Demul
« Reply #6 on: August 17, 2008, 09:20:25 pm »
If you need help pm me
Jdurg
Re: Demul
« Reply #7 on: August 18, 2008, 01:32:38 pm »
I got it running.  Everything's good now.   ;D
1): 49,500
2): 35,600
3): 30,100
4): 29,400
5): 28,200
nipsmg
  • Last login:March 02, 2026, 07:54:33 pm
  • ROONEY!! ERRGH!!
    • Arcadia
Re: Demul
« Reply #8 on: August 18, 2008, 02:38:30 pm »
jdurg:
I'm curious.  What works/doesn't work in the new build of Demul? Are there working playable NAOMI games?  do they run at full speed?  If so, which ones?  What's your system specs?
Jdurg
Re: Demul
« Reply #9 on: August 21, 2008, 08:59:52 pm »
Demul is a bit finicky.  I would highly suggest getting the new NullDC NAOMI emulator if you want to play NAOMI games.  The readme.txt does a good job of explaining what you need to do to get games running, and if you have the gdrom versions of games you'll need the decryption keys from the MAME source for NAOMI.  (naomi.c).
I've only got Street Fighter Zero 3 Upper and Capcom Vs. SNK 2.  My computer is a Core2Duo Penryn at 2.50 GHz  (T9300) with 4GB of RAM on Vista-64 bit.  I SFZ3u isn't properly emulated yet so the sound doesn't work and the input doesn't work either.
Capcom Vs. SNK2 runs 100% and is utterly beautiful.  No problems at all.
The current version of NullDC doesn't have gamepad support, but that will supposedly be added back in shortly.
So I would suggest ignoring Demul and going wih NullDC or Makaron when it is released.
1): 49,500
2): 35,600
3): 30,100
4): 29,400
5): 28,200
