Author Topic: Stronger bond - wood glue or contact cement?  (Read 3502 times)
« on: July 12, 2008, 04:18:23 pm »
I'm bending a 1/8" thick hardboard panel around an 8" curve and I want the strongest bond possible.  Any thoughts?  Does it even matter?
jan25th
  • Last login:February 09, 2026, 04:21:37 pm
  • Long time lurker
    • forum.arcadecontrols.com/index.php/topic,147244.0.html
Re: Stronger bond - wood glue or contact cement?
« Reply #1 on: July 13, 2008, 03:47:41 am »
It depends on what you are gluing the hardboard to. I haven't had very good results using yellow (carpenter's) glue on hardboard and would suspect contact cement would be better, would need to rough up the hardboard first and apply a couple of layers of cement to the hardboard. I think a better alternative would be something like PL400, it can be messy and difficult to clean, so be careful, but it is a very good adhesive.
Chadwick
  • Last login:January 11, 2010, 03:23:34 pm
« Reply #2 on: July 14, 2008, 08:50:56 am »
I think construction adhesive might work well in that situation.
« Reply #3 on: July 14, 2008, 01:21:11 pm »
I ended up using wood glue to glue the hardboard to another sheet of hardboard.  I let the thing sit for 24 hours all clamped up and it seems to have worked....
